1. The most important thing about buying a new bike is to make sure it fits. The only way you'll know if the bike is right for you is to size up the bike and make sure that the bike's geometry matches your body's geometry. Ask questions and do some research.
mtn. biking 101
2. If possible, try to find a shop that will let you demo the bike on real dirt. Five minutes in a parking lot won't cut it. You wouldn't buy a car without a real world test drive, and a bike should be no different.
3. Don't belive the hype. Just because your favorite rider or best friend rides a certain bike, that doesn't mean that's the best one for you. Have an open mind and be realistic about your needs and ability.
Results 1 to 7 of 7
    Feb 2012
    SRAM S800 crankarm removal?
    I'm having a hard time finding formation on how to remove the crankarms from a sram s800. I got the crankbolt off, but I guess these aren't self-extracting and I'm going to need another tool.
    Will I need a crank puller for square or tapered cranks?
    Thanks.
    2002 Giant Rincon
    2012 Diamondback Podium 3
    2013 Specialized Stumpjumper EVO 29
    2013 Giant Anthem X Advanced 2
    Probably drunk right now
    Reputation: Ken in KC's Avatar
    What bottom bracket?
    Quote Originally Posted by stop619 View Post
    Thanks.
    You'll need a crank puller specific to the type of bottom bracket you have.
    JPark - 3.5- don't listen to dremer
    Feb 2012
    Quote Originally Posted by Ken in KC View Post
    The spec sheet for my bike says sealed cartridge.
    Diamondback Bicycles - 2012 Overdrive Comp
    2002 Giant Rincon
    Well....
    It looks like it's a splined (ISIS) bottom bracket. You'll need a crank puller specific to a splined bottom bracket. Also note, there's usually a retention ring nested inside the crank arm that serves as a washer for the crank bolt. You'll want to ensure that ring is out before you remove the crank arm.
    Feb 2012
    Thanks for the help!
    2002 Giant Rincon
    Any time...
    Any time. Let us know how it goes. Cheers,
    Ken
    Feb 2012
    I picked up a Park Tool CCP-44 and the crank came off easily. The bottom bracket is a
    Truvativ Powerspline.
    According to Jensonusa Truvativ Powerspline BB > Components > Drivetrain > Bottom Brackets | Jenson USA Online Bike Shop
    Proprietary spline design popular as OE spec with many moderate-price TruVativ cranks.
    Please note: this item is NOT ISIS Compatible
    2002 Giant Rincon
