Results 1 to 15 of 15
    Mar 2014
    sram 1050 cassete moving
    Hi, Why moving Chainrings, they have become ground .
    video
    It looks to be a little loose. You can buy the tool and DIY or if you take the wheel to your local shop they'll likely snug it up for free.
    Mar 2014
    Thanks, i buy the tool and try to do my self.
    Sep 2012
    One of two things, either you are missing a spacer that goes on the freehub before the cassette goes on (locking ring cant seat the cassette fully) or the cassette locking ring is loose.
    you will need a SRAM/Shimano lock ring tool, a chain whip and a crescent wrench.
    My Giant's - 2014 Propel Adv Di2 - 2014 TCR Adv SL4 - 2014 Anthem Adv 27.5 - 2014 XtC Adv 27.5 - 2014 TCX Adv Pro
    there is something wrong there. I'm guessing the chain rings weren't put on right in the first place. Even a loose lockring wouldn't do that I think..
    buy the right lockring tool for your lockring (take a picture and post it if you don't know).
    get a chain whip, i like this one: 3 in 1 Function Bicycle Chain Whip Bike Bottom Bracket Tool Lock Ring Tool | eBay
    take the lock ring off and slide the chainrings off. When you reinstall them, make sure you align the chainrig inner notches correctly.
    Sep 2012
    There is no way to put the chain rings on wrong, there is a indexing notch that is skinner than the rest of the notches. Only allows you to put the rings on in one position.
    Have you ever taken the cassette off of this wheel or had a shop take it off?
    Reputation: Shakester's Avatar
    Jun 2012
    On a 10 spd cassette like yours, its usually the first 2 that are separate pieces. The 3rd one that has wiggles would make me believe that the whole cassette does. It might be a worn out freewheel. But, its always a good test to remove it and inspect it, then reinstall it.
    Cassettes consist of cogs, not chainrings.
    Reputation: El Cheap0's Avatar
    Mar 2013
    I have been wanting to overhaul my rear wheel, but it's my first time so I don't know which tools I need. I know I need a chain whip, a lockring holder or remover or something tool, and a crescent wrench, which I have. Are there different sizes of chain whips and locking remover tools?
    I looked at other threads but couldn't seem to figure out my questions. Also, where can the chain whips and lockring holders be found for under $25 for both?
    I made a chain whip with a piece of chain and metal ,it didn't cost anything.The lock ring tool should be under $10.
    Mar 2013
    Yeah I see I can just use a glove and a rag in place of a chain whip, but for the lock ring tool, Park Tool has different model types, and some say they're made for shimano and others don't specify which model they're made for. I have SRAM shifters and derailleurs, and SR Suntour cassette in front (can't see a brand on rear cassette, but everything is stock), so probably suntour in back too.
    Does it matter which one I buy? Thank you
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by rangeriderdave View Post
    ^^^ Much better than a rag.
    Most any lockring tool will do, SRAM/Shimano are the same. It's worth it to get one with a lineup pin.
    Reputation: time229er's Avatar
    Oct 2013
    that sure appears to be a worn freehub...especially if the hub is aluminum. The cog movement is front to back. If it wobbled side to side, a loose lockring or missing/mis-placed spacer could be the culprit, but I have never seen a lockring loosen up if tightend even close to spec. Has it been apart recently? It really don't make any difference, either way it's got to come apart.
    2014 Nail Trail 29...
    Quote Originally Posted by time229er View Post
    Cassettes can actually move like that due to a loose lockring, some freehub body/cassette combos more than others. I've seen a lot of loose lockrings too, though that one must be extremely loose if nothing else is wrong (missing spacer, etc.). Some people tighten them with their fingers.
    Oct 2013
    Quote Originally Posted by J.B. Weld View Post
    really??...with their fingers??...OMG let's hope the OP fills in the blanks!
  1. Replaccement big ring for xx sram cassete
    By Bazz6666 in forum 29er Components
    Last Post: 03-08-2012, 09:46 AM
  2. Which SRAM 10 speed cassette, PG-1070, PG-1050?
    By trhoppe in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-05-2012, 12:13 PM
  3. SRAM PG 1050 Spacers
    By LowOnO2 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-01-2012, 05:42 PM
  4. SRAM PG 1050 & XT 10sp 11-36 weight
    By westin in forum Weight Weenies
    Last Post: 02-03-2012, 07:34 PM
  5. Sram pg 1050 vs 1070
    By meSSican in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-28-2011, 05:57 PM
