Results 1 to 5 of 5
Thread: Squeaky headset
    May 2013
    Squeaky headset
    When I turn the bars it sounds like an old door creaking. Bars move freely and I've tried loosening the preload and stem then retightening. With everything completely loose there's no noise so I guess it's the spacers rubbing. Should I be concerned?
    Mar 2013
    Mine did the same. It was the rubber gasket at the bottom of the spacers rubbing on the head tube. A little lube and its gone.
    Reputation: Gasp4Air's Avatar
    Every part of the head set assembly should get a coating of grease. If you think the spacers are squeaking, lightly grease them too.
    Also, check the installation guide to ensure everything is in the right place and oriented correctly.
    Use it, use it, use it while you still have it.
    May 2013
    Thanks for the advice, will lube
    Apr 2013
    Also check your fork, if it is a creaking sound could be the guides in the for leg on the non sprung side, assuming it is a coil sprung fork.
  1. Squeaky, squeaky....
    By TysonTy1 in forum Ventana
    Last Post: 06-26-2012, 05:42 PM
  2. Squeaky Rear
    By FroggerRacing in forum Shocks and Suspension
    Last Post: 01-17-2012, 06:20 PM
  3. Squeaky Ride
    By JetFuelOnly in forum Shocks and Suspension
    Last Post: 07-27-2011, 02:52 AM
  4. Squeaky brakes
    By Smilerz in forum Ibis
    Last Post: 07-02-2011, 07:10 AM
  5. Altitude 50 RSL Squeaky Headset
    By skrap1r0n in forum Rocky Mountain
    Last Post: 05-24-2011, 09:56 AM
