Results 1 to 14 of 14
Thread: Squeaky brakes
    Squeaky brakes
    hi,
    I have a Marin Bolnas Ridge.
    And the breakes are sqeaky.
    What is the remedy to this?
    And would i be able to buy shocks for this bike?
    Should be easy to fix, do you have rim brakes or disc?
    Basically, it is a setup issue. Let us know what kind of brakes you have so we can give good info....
    How can i tell what type of brakes it is?
    There's no app for this.
    Reputation: JimC.'s Avatar
    You have a Marin Bolinas ridge, an entry level alloy hardtail bike with V-style brakes.
    Take it back where you bought it and have them adjust the brakes if they are noisy. Check the rims for true.
    Read up on your bike here: www.sheldonbrown.com
    If you don't know what you have and how it works, expect a pretty miserable biking career. It's a good bike, get to know it and maintain it well, and you'll have a blast. Ignore it and it will fall apart and you'll stop riding it.
    Good luck, Jim
    I bought it for a friend.
    And so there fore i can't return it.
    How can i fix the brakes?
    What types of satnds can i buy?
    Huh?
    Quote Originally Posted by 777heavy
    ...take it back to where you bought it and have them check it.
    >Read the URL I gave you.
    What types of stands can i buy?
    >Any kind you want.
    here's one more handy site: http://www.iespell.com
    Jim
    Where can i buy the stands?
    Local Bike Shop (LBS)
    High end sporting good store like REI
    Web based bike vendors like Janson USA, Nashbar, etc
    E-Bay
    Burninator
    Reputation: trogdor's Avatar
    Preemptive post
    http://www.parktool.com/repair_help/...arbrakes.shtml
    Go there and scroll about half way down the page. It tells you how to stop your breaks from squeaking.
    Only twenty minutes ago he had decided he would go mad, and now here he was chasing a Chesterfield sofa across the fields of prehistoric earth.
    My bike looks TOTAL different from that!
    its red and their is alot more differences( side of the bike said it was a coustom)
    is that ok?
    is that ok?
    No that's not OK. A bike should NEVER be red. It only be blue, yellow, black, or sliver. Under right conditions it can even be purple, but never red.
    Burninator
    I disagree
    Quote Originally Posted by wraith
    ONLY when the side of the bike says it's a "coustom" can the bike be red.
    Why can';t it be red?
    why can't it be red?
  1. Need advice on using disc brakes
    By moose in forum Brake Time
    Last Post: 04-05-2004, 11:18 AM
  2. New brakes?
    By tmaybee in forum Weight Weenies
    Last Post: 04-05-2004, 05:56 AM
  3. Ahoy! V-brake holdouts!
    By Padre in forum Singlespeed
    Last Post: 03-23-2004, 10:06 AM
  4. Disc brakes for 2004 blast
    By variegatus in forum Kona
    Last Post: 03-13-2004, 11:17 AM
  5. regular brakes and disc brakes
    By joshua_msu in forum Brake Time
    Last Post: 03-05-2004, 09:07 PM
