Results 1 to 11 of 11
    Jun 2013
    space in between bottom of crown race & top of fork crown
    Hi. I'm prepping for my new fork install. Done many on BMX, but never on mtb & never on a front shock fork. Just out of curiosity of wanting to see if I have every headset piece, I slipped the crown race onto the steerer tube, without any force. Crown race is just laying there. I didn't use a PVC pipe to bang it down yet. There's about 1/4 to 5/16 of space in between the bottom of the crown race & the top of the fork crown. If I push it down with hand strength, it'll probably only go down another millimeter. Am I to believe that banging it down with a PVC pipe will set it onto the fork crown completely? I'm afraid of chewing away the steerer tube. (first pic is bottom cup, cartridge bearing & crown race with seal, upside down.) Thanks
    specs:
    headtube 1.5
    Fox front fork steerer tube 1-1/8 to 1.5 tapered
    Cane Creek headset 1-1/8 to 1.5 tapered
    space in between bottom of crown race & top of fork crown-img_1118_snipped_mtbr.jpgspace in between bottom of crown race & top of fork crown-img_1120_snipped_mtbr.jpgspace in between bottom of crown race & top of fork crown-img_1123_snipped_mtbr.jpgspace in between bottom of crown race & top of fork crown-img_1124_snipped_mtbr.jpg
    T.W.O.
    Reputation: mimi1885's Avatar
    It needs to be flushed.
    Reputation: shiggy's Avatar
    Dec 1998
    Crown races are interference fits. Needs to be driven into place. That is why crown setting tools exist.
    And grease it first.
    mtbtires.com
    Sep 2013
    It needs to be flush with the crown. I've seen it done and even mechanics use a pipe to seat this onto the steere tube. You won't chew the steerer tube away.
    I'd see if the blue seal comes off easily before seating.
    Crown race seating - home made
    Jun 2013
    Quote Originally Posted by mimi1885 View Post
    Yes thanks, i understand that. Another thing is i've seen used shock forks on eBay that don't appear to have any scratches just above the fork crown, which made me go hmm. I thought at the most, there'd be 1/8" of space or less, before i bang down on it
    Jun 2013
    Thanks all & thanks shiggy on the grease tip
    T.W.O.
    Quote Originally Posted by TheeSuperUberV View Post
    Use the proper tools to install an remove the crown race. I don't have any marks on my forks either, but if I do who cares, it's ok
    FWIW, I've used the pipe/hammer/screwdriver installation method hundreds of times without a single issue.
    T.W.O.
    Quote Originally Posted by slapheadmofo View Post
    Yeah, I did that a few times when I started out, it was a peta to find the right size pipe. Then I bought the cheapo when I started doing more swapping. Now I'm on the park tool set, still don't do hundreds of times, may be 12-20 times a year.
    Jun 2013
    also, in case of resellability reasons... but i will go ahead & just bang it as prescribed
  1. Should a crown race already be on a new fork?
    By Cube_rider in forum Shocks and Suspension
    Last Post: 06-18-2013, 10:09 AM
  2. New frame and fork, crown race questions?
    By zblee in forum Shocks and Suspension
    Last Post: 05-16-2012, 12:04 PM
  3. Fork Crown Race Question
    By Dango Dog in forum Niner Bikes
    Last Post: 03-28-2012, 01:02 PM
  4. Loose bottom crown race on Float 36?
    By peterpiper in forum Shocks and Suspension
    Last Post: 06-12-2011, 04:38 PM
  5. Replies: 6
    Last Post: 08-10-2010, 06:43 AM
Members who have read this thread: 8
