Thread: Snake Bite???
    Reputation: GT0neX's Avatar
    Feb 2007
    New question here. Snake Bite???
    Pardon my noobish ignorance , but what does a "snake bite" flat refer to? Is it really a snake bite that punctures the tires or does it refer to a type of flat where you end up w/ two air leak holes???
    Time is not a road.
    Reputation: chad1433's Avatar
    If the tube gets pinched between rim and the tire it can cause two puncture holes in the tube often referred to as a "snake bite" or "pinch flat".
    Barring going with a tubeless set up, you can use talcum powder inside the tire to keep the tube and tire separated making it somewhat less likely that bottoming the tire on the rim will result in a pinch flat.
    Feb 2007
    thanks! i know my buddies over here would laugh (in a friendly way of course) if I asked.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    And put enough air in the tube.
