Results 1 to 3 of 3
    Reputation: MikeyR's Avatar
    small popping felling
    ok I was riding my bike on the trails with a friend and after a while I noticed a small popping feeling when I pedal. Is it needed to buy a new bottom bracket or do I need to take it to a bike shop and get them to just lube the bottom bracket or what.
    Specialized hardrock sport 29er Disk
    givin to me. 26in. next brand hardtail
    Reputation: Gasp4Air's Avatar
    Sounds and "popping feelings" can be hard to isolate. Given the lack of detail in your description it's impossible. It could be lots of things, and there are lots of ways to try to find the problem. I suggest you let your LBS sort it out.
    Use it, use it, use it while you still have it.
    Pimpmobile
    Take it back to the shop. It's a new bike and they should go over it for free. Sounds like something is loose like a pedal or crank bolt.
    "Fear not the ob-stackles in your path"
