Results 1 to 17 of 17
    Aug 2013
    Slipping seatpost even with new salsa clamp
    Recently bought a new Scott Scale 960 29er. Initially had problems with the seat post slipping so after reading about similar problems and recommendations, bought a 35mm salsa flip lock clamp to replace the stock clamp. I degreased the post, put a light smear of teflon grease on the post and have done it up to the correct torque settings. Now the bloody thing is even worse. Went for a ride today and must have stopped over 10 times to keep lifting the post back up.The seat was even moving left and right if i knocked it with my leg. Tried wiping some of the grease off as this has seemed to have made the problem worse. How tight can you go before damaging the frame as theres not a lot of resistance to open and close the clamp. Is this how it should be or should i have to use some force to close the clamp?
    Reputation: J.B. Weld's Avatar
    Quote Originally Posted by chuzzwuzzer View Post
    When you say "correct torque settings", are you talking about the QR lever? That is adjustable and should be set so it clamps down tightly, it shouldn't require a lot of force to close it but there should be a fair amount of resistance. I'd try tightening it.
    Aug 2013
    Yes.I have fitted the salsa QR lever. Closed it and done it up to the specified torque settings. In the manual it states Seatpost seatclamp torque settings:
    M4 2.8-3.9 Nm
    M5 5.6-7.8 Nm
    M6 9.8-13.7 Nm
    Stand-up philosopher
    Reputation: drwx's Avatar
    Re: Slipping seatpost even with new salsa clamp
    You could try some of that grease for carbon fiber seat posts. It's gritty.
    http://www.amazon.com/Finish-Line-Bi...sh+line+carbon
    Stephen
    stephen
    no one can appreciate the poor misunderstood
    M4 2.8-3.9 Nm
    M5 5.6-7.8 Nm
    M6 9.8-13.7 Nm
    How do you measure torque on a QR lever?
    Aug 2013
    By using the torque wrench to tighten the allen bolt when it is closed ?
    Got it, I didn't know that QR had an allen bolt. I'd still tighten it a little.
    Nov 2008
    If you use a wrench to tighten down a quick release, well Your not using it for its intended purpose. Its meant to be tightened by hand. If you want to be all meticulous (unnecessarily) then by a non qr bolt through.
    I can't believe this was even posted on here. You got a quality clamp, now clamp the s*** out of it
    Sent from my LG-P769 using Tapatalk
    Aug 2013
    Yes its meant to be used by hand but the initial install surely should be done to the correct settings ? I dont carry the torque wrench around with me on rides ! I'll try clamping the shit out of it then lol
    Nov 2008
    Built over 20 bikes, but never a torque wrench. Unless I'm in the inside of an engine will I find the need for one.
    Ride hard
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    I wonder if the torque spec is meant to be set with the QR in the open position...
    anyhow I agree with the others....just tighten the shit out of it.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    The best setting for QR skewers is "as tight as you can operate without tools such as extension levers or a hammer".
    If you're particularly strong, maybe you don't need to go as far, but regular folks should "oomph" a bit when closing the lever. Weaker individuals should tighten it to the point of actually struggling a bit.
    Reputation: 11053's Avatar
    You said you degreased the post, but then you then lubed it again.
    Did you degrease the frame?
    If not, you didn't degrease anything and you may still have too much grease in there.
    Wipe down the post and wipe out the seat tube.
    Install the post "dry" and see if the slipping stops.
    If it does, then just apply a very light coating of grease and tighten down the clamp a bit more and you should be good.
    If you've got too much grease, even cranking down the QR may not be the fix.
    Fix should be the balance between minimal grease and clamp pressure.
    go with the carbon seat post paste. It will solve your problem.
    Reputation: time229er's Avatar
    Oct 2013
    yep...
    degrease, apply gritty shit, tighten clamp, give it a kiss next...
    Attached Thumbnails Attached Thumbnails Slipping seatpost even with new salsa clamp-616shv%252bikel._sl1500_.jpg
    2014 Nail Trail 29...
    I have a Scale 29 Comp and had trouble with the seatpost dropping. Talked to my lbs about it. He measured inside the seat tube. We switched from the stock 31.6 to a 31.8 seatpost and that solved my problem.
    DFMBA.org
    Reputation: MTBeing's Avatar
    I have a similar issue with a steel h/t frame, carbon post and a 30.0mm QR Salsa clamp. The clamp has a 4mm hex bolt opposite the QR so I just tighten it with a torque wrench in the closed position. I've used Finish Line since the initial install and slowly crept up from 5nm-6.5nm and the post still slips about 0.25" every ride even if I tighten the bolt prior to a ride. I tried turning the clamp 180 degrees so that the clamp split matches to the frame split and things were actually worse. Now I'm gonna try no Finish Line and a clean seat tube at 7nm clamp force and see what happens (dry/dry). So close...yet so far.
    Please donate to IMBA or your local IMBA chapter. It's trail karma.
  1. Slipping Seatpost
    By JRA in forum Tooltime
    Last Post: 11-16-2012, 07:46 PM
  2. ritchey wcs seatpost - slipping saddle clamp
    By bob13bob in forum Ritchey Design
    Last Post: 07-16-2012, 05:20 PM
  3. Seat post clamp slipping
    By Fourtango in forum Clydesdales/Tall Riders
    Last Post: 06-06-2012, 07:09 PM
  4. Fittin on stronger seatpost clamp? - slipping. Monocog 29er
    By ZmyDust in forum Clydesdales/Tall Riders
    Last Post: 07-14-2011, 04:22 AM
  5. Slipping seatpost
    By cruzthepug in forum General Discussion
    Last Post: 02-02-2011, 03:43 AM
