Results 1 to 7 of 7
    Jan 2011
    SKS airchecker and tyre pressure
    Hi,
    I got the SKS airchecker pressure gauge and tried it on my MTB tyre (Bontrager XR2 26*2.1 ) which has schrader valve.
    The recommended pressure on tyre range is 30 - 50 PSI. I checked with the gauge and it showed 38.5 PSI. The tyre seemed to be bulging slightly in side and almost filled up. It did not seem like it could take more than little more air.
    Is the gauge off by a bit or have I misunderstood something?
    I pressed the schrader end of gauge to valve at 9' o clock position for a few seconds and took the reading.
    Thanks in advance.
    Reputation: J.B. Weld's Avatar
    Are those tires tubeless or do you use inner tubes? Either way if a tire is not seated right it can blow off a rim long before it gets to the maximum pressure rating, and a lot of times if you see a bulge in a tire it isn't seated correctly. A tire with an inner tube can be easily be inflated to it's maximum pressure and beyond without fear of it blowing off as long as the bead is evenly seated but if you're riding off road you'll want to keep the pressure very low, often lower than the minimum recommended pressure.
    Fat-tired Roadie
    Nov 2007
    Recommended by whom?
    As JB Weld is saying, off-road riding benefits from really low pressures. Your tire is supposed to deform. That's why pneumatic tires were such a big deal when the guy who invented them got them figured out.
    Jan 2011
    Hi, I was referring to the pressure range imprinted on side of the Bontrager tyre. My query is : perhaps my air pressure gauge is off the mark (showing little lower than the actual ?)
    Jan 2011
    P.S : They are not tubeless tyres and do have inner tubes.
    Reputation: HillbillyTom's Avatar
    Sep 2012
    Best bet is to compare the gauge to some others. Borrow some of your buddies' tire gauges, use a car tire (more volume so you can do multiple checks without the pressure fluctuating as much) and see how your gauge readings compare to the others. I have found that not all gauges are accurate, and some can be waaay off base.
    Salsa El Mariachi 29er
    Giant CFR Team Road Bike
    Kona Jake the Snake
    '03 Yz250
    '05 Ducati 749
    Fat-tired Roadie
    Nov 2007
    Re: SKS airchecker and tyre pressure
    Quote Originally Posted by sanjayc View Post
    As long as it's repeatable, it's good enough.
    If you want to compare to a floor pump, use a reading you had to inflate some to get to. Pumps have a check valve that can cause them to underreport if you just stick the pump on the tire and don't pump it up.
  1. Tyre Pressure & Front Suspension Pressure on 2009 Badboy
    By fumi in forum General Discussion
    Last Post: 07-05-2013, 10:30 AM
  2. Tyre pressure
    By frith97 in forum Downhill - Freeride
    Last Post: 04-26-2013, 02:32 PM
  3. UR tyre pressure - weight - tyre size - ride type
    By John Lazzara in forum Wheels and Tires
    Last Post: 02-22-2013, 09:14 PM
  4. Tyre pressure
    By scuboo in forum Wheels and Tires
    Last Post: 01-25-2013, 10:36 AM
  5. Max tyre pressure
    By podoco in forum Beginner's Corner
    Last Post: 09-26-2012, 10:05 AM
