Results 1 to 6 of 6
    Skewers to through-axles?
    Prior apologies for the double-post.
    I can't seem to find directions for swapping out a QR skewer for a 10mm through-axle, to fit on my horizontal drops. Can anyone shoo me in the right direction, or offer advice, please?
    Best.
    Oct 2010
    If I'm not mistaken you have to change the hub but dont quote me on that. Ty calling your local LBS and see what they say.
    Former Bike Wrench
    Thru axle requires specific dropouts, but your hub may be convertible to a thru bolt or a bolt up axle. What kind of hub (brand, model) is it?
    ^ Most QR dropouts will fit a 9mm axle up front and a 10mm rear.
    OP, it depends entirely on your hubs. My front hub fits standard QR, 9mm, 15mm, and 20mm with certain adapters that came with the wheel. My rear hub will use standard QR or 10mm.
    All of the true things I'm about to tell you are shameless lies.
    Fat-tired Roadie
    Nov 2007
    Horizontal dropouts don't necessarily require a through-axle. Singlespeed bike? What frame? Pics?
    Former Bike Wrench
    Quote Originally Posted by False View Post
    You need to know the difference between a thru axle and thru bolt...they are not the same. A through axle uses specific drop-outs where the axle actually threads into it. X-12, QR15, 20mm are examples of thru axle.
    Through bolt is simply a 9mm or 10mm thick bolt or skewer that runs in the standard drop-outs.
  1. New DT Swiss RWS skewers/axles
    By rockyuphill in forum Weight Weenies
    Last Post: 10-10-2012, 07:46 AM
  2. Switching out QR skewers for axles
    By bisicklay in forum Downhill - Freeride
    Last Post: 07-31-2011, 11:53 AM
  3. Who makes 9mm front wheel skewers (axles, bolts) ?
    By ozvena in forum Wheels and Tires
    Last Post: 08-18-2009, 12:57 PM
  4. Replies: 6
    Last Post: 06-20-2009, 11:37 AM
  5. Replies: 0
    Last Post: 01-06-2009, 08:01 AM
