Results 1 to 3 of 3
    Single Speed Conversion
    Hello, new here and was just wondering if anyone had any ideas i hadnt thought up yet. Im trying to set up my schwinn alure (89) to a single speed free wheel. I was able to get a good gear ratio with good chain tension using a bmx rear cassette but my chain alignment is off and i can not space the front gear any closer to the frame because of clearance and i tried to get the back cassette to sit further away from the hub but im not getting it out far enough. Any products out there to help space that cassette out from the hub more? Im just running out of threads. Any help would be greatly appreciated!
    www.bigrobracing.co.uk
    Reputation: robdeanhove's Avatar
    Dec 2005
    Maybe move the front chainring inwards, to the middle ring position, rather than try and move the rear sprocket out, this is what most people do.
    There's a dedicated singlespeed forum if you want to pop over there?. Probably worth taking a picture of your setup and I'm sure someone will pop up with a good solution
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    If it's a freewheel hub you can change the spacers on the hub itself, spacing the entire wheel over. Then you should have the wheel re-dished.
    Another option may be to go with a smaller front ring that would give more room to space the ring inward without it hitting the chainstay, then go with a smaller rear freewheel to give the same gear ratio.
    "...like sex with the trail." - Boe
  1. Single speed conversion ?'s
    By Got Wheelz? in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-24-2010, 08:24 AM
  2. single speed conversion
    By ILUVGT in forum GT
    Last Post: 08-21-2008, 07:25 PM
  3. SIngle Speed Rear Hub or Single Speed Conversion
    By cmil1 in forum Singlespeed
    Last Post: 02-13-2007, 03:09 PM
  4. single speed conversion
    By FrankBooth in forum Singlespeed
    Last Post: 02-22-2006, 12:31 PM
  5. single speed conversion
    By WillyT in forum Singlespeed
    Last Post: 04-12-2005, 03:37 PM
