Results 1 to 5 of 5
    SID XC Rear Shock
    Hi
    When i try to set up my rear shock i pump the - chamber upto 50psi then the + chamber up to 175 psi but when i recheck the - chamber its way up to over 100psi is this normal or is my shock screwed
    sorry if this is a stupid question
    thank you
    craig
    Jul 2003
    Sounds like you have a leak....
    in the seal between the - and + chambers. This is not that uncommon. The seals need to be or should be replaced on a fairly regular basis, about every 2 years or so. The shock isn't screwed, just in need of a rebuild/service. The best way to check is to empty the - chamber, then fill the + chamber. Then check the - chamber. If there is pressure in the - chamber after filling the +, then you have a leak between the two chambers and the seals need to be replaced.
    Good Dirt
    ~I Ride In Circles ~
    Reputation: ZoSoSwiM's Avatar
    Dec 2005
    My SID recently started leaking from the - chamber. I'm looking into a rebuild kit but I'm going to try a warranty first.
    ~ it's all good ~
    ... and if we just ...
    thanks squash will look into changing the seal any idea where i can get the service manual for the sid shock
    cheers
    Former Bike Wrench
