Results 1 to 36 of 36
Thread: Shrek sperm
    Reputation: GreenCanoe's Avatar
    Oct 2012
    Shrek sperm
    Guys, just don't slime your tubes. There's really no point. My LBS suggested that I use it to help mitigate flats with all the broken glass out on their local trail. It seemed odd that the best suggestion they would have was this crap. Oh well. I buy tubes in bulk anyway - at least for a little while longer. Its not really the weight its the balance issues. If you slime your tubes then spin your wheels, you'll notice how bad it is. It does even out after while, but it never really goes away completely. After the eight bucks on slime and whatever you pay for tubes (for me ~8.00 at the LBS or 3.50 online) it's a waste of money. I just fixed a flat on the trail out there today, and I decided to keep the tube to show how useless this stuff is. Tiny pinhole, and the slime didn't do a thing for me.
    "Faster, Faster until the thrill of speed overcomes the fear of death." - Hunter S. Thompson
    Dec 2011
    Looks like slime evenly coats the inside of your tube it has to be better than stans
    'Tis but a scratch
    The only time I had slime in my tubes was when my brother and I rented a couple MTBs out in the desert in Blue Diamnond, NV. This was a little excursion while on a Vegas trip. Between the 2 of us, we got 3 flats that day. Lot of good slime did for us.
    Jan 2009
    any LBS that actually recommends using Slime products deserves a boycott.
    Dec 2011
    Quote Originally Posted by mack_turtle View Post
    ditto
    I made the mistake of buying a slime tube. I had to carry pliers with me because the valve would freeze with slime and you couldn't open it without them.
    Never again.
    High Gravity Haze
    Reputation: Spec7's Avatar
    May 2000
    Pin hole flat solution: Pre-glued patch kit and check the tire to see if whatever caused the flat is still there. Far cheaper than a new tube & takes about the same amount of time to do as to change a tube.
    Cormac
    Reputation: cormy's Avatar
    just go tubeless....?
    '11 Dawes Deadeye
    '12 Niner E.M.D. 9
    '09 Giant ocr c1
    Xtracycle
    Oct 2012
    Quote Originally Posted by cormy View Post
    Planning on it, but I want to wear down the tires I just bought a couple months ago before I spend $180.00 on a tubeless setup. I'm riding around town at night now to help speed that process along...then I need to get permission from the ol' ball and chain.
    Ski N Bike Tech
    Reputation: SkiNBike's Avatar
    any lbs that actually recommends using slime products deserves a boycott.
    +1.
    Afric Pepperbird
    Reputation: dirt farmer's Avatar
    Mar 2005
    Too true, too true!
    I4NI
    Reputation: S_Trek's Avatar
    May 2010
    Mine rec. tire liners
    There....Are... Four...Lights!
    Sep 2012
    ive never used slime. However Ive never once had a single flat using liners.
    Just some yahoo on a Wahoo
    Dec 2011
    Quote Originally Posted by GreenCanoe View Post
    You don't need to spend that much to go tubeless and why don't you just do it with your current tires?
    Oct 2012
    Im guessing ~60.00 for the Stans rim strip and sealant kit thingy, then new UST tires. The tires I have on there i wouldn't trust to even attempt a tubeless setup with. I grabbed some cheapo Duro tires in a pinch. I regret that decision...
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Don't need UST tires to run tubeless. As long as you're using sealant you can use [nearly] any tire. Look up "ghetto tubeless" which works great and costs as much as 2 24" tubes and a bottle of Stans.
    Reputation: Danielrg_usa's Avatar
    I use to run the slime tubes and honestly they never gave me any issues. I ran a pair of tubes for a year and only once did one fail to to not seal. I do think they have their place and I do recommend them when people say they are going to give them a try. However, now that I have gone tubeless and have seen the benefits for myself I'll probably never go back.
    Sent using my fat thumbs!
    Sep 2012
    Quote Originally Posted by zebrahum View Post
    ^^ This... and using a non-UST tire can save you around 1/2 lbs per tire.
    It's also very easy to seal up rims with Stan's yellow tape.
    -S
    Oct 2012
    Quote Originally Posted by shibiwan View Post
    -S
    Ive looked into several of the ghetto tubeless setups (gorilla tape, half of a stans kit, paper mache' and all kinds of other hilarious enterprises undertaken by individuals that can only be described as "mentally hilarious"), and the results have seemed to be optimistic at best. These setups are very highly dependent on the rim/tire/sealant/pressure choice - much more so than with a kit. Since I run Bontrager AT-850's, and Taiwanese frowny tires, I figured tubes were the best option while I save up. However, if you more experienced riders maintain that it's a viable option, I will likely look more into it, probably with some PMs and eventually a thread about my success or failure.
    Dec 2012
    Whats the point of going tubeless? Is there a benefit other than the weight saving of the tube?
    Quote Originally Posted by speadphreak View Post
    Less punctures and even lower pressures,I want to go tubeless aswell but my dad says its a royal pain in the a*rse if you still puncture or if your swapping tires often.
    EDIT: 300th post, oh yeah!
    Oct 2012
    Weight savings, low tire pressure which leads to better traction and fewer punctures, financial gains if you worry about a four dollar tube (or .50 cent patch), when you do get a puncture, the sealant in the tire does wonders to plug it (see below).
    Quote Originally Posted by Wasmachineman NL View Post
    .EDIT: 300th post, oh yeah!
    Congratulations, bud.
    EDIT: UST tires generally have a thicker more durable carcass helping their resistance to punctures. A couple other riders telling their favorite stories about their tire installation wile I was in the local shop one time, and I walked away with some useful information. While you are initially installing your tubeless tires, you have a pool of sealant in the bottom of the tire. Should the bead blow off or not seal properly, your sealant will more likely than not be blown all over the place when you go to air it up, and your normally lovely wife will shortly become a fire breathing dragon as soon as she sees it. I guess something to keep in mind.
    Reputation: masterofnone's Avatar
    I've never used a ust tire and have been going tubeless for years now. They do have a thicker more durable carcass though. Regardless whether you go ust or not you're still going to need a tubeless rim or go stan's. My recommendation? Go stan's and use whatever freakin' rim and tire you want. BTW I have had the beads blow off twice, once blowing sealant all over the beach and once in my face when the bead snapped. Hilarious yes, very LOUD, and messy lol
    Picture Unrelated
    Jun 2005
    Ghetto tubeless works great, yellow Stan's tape works great if you can get the tire to seat (I have one tire that works and one that doesn't running non-UST tires), and UST tires with Stans rim strips work great. Sure it's dependent on how your tire and rim fit (tighter = better) but it's not a situation where you should say that UST is the only way to go.
    UST tires do not have "thicker more durable carcass" no matter how poor the grammar is there. UST tires have a [typically] butyl layer built into the casing for air retention (means you don't need sealant) and the bead is a locking type which creates an air tight seal. Actually, the seal is what defines a tire as UST, without that it's "tubeless ready" or one of the many variants.
    I still have a mental image of the results of a co-worker at our shop blowing a tubeless tire off the rim and leaving a shop manager shaped clean spot on the wall. He didn't find it as funny as the rest of us, but it took a long time for us to get our hearing back.
    Gorilla tape here for almost two years.
    Jonesin'
    Reputation: ForrestJones's Avatar
    Lol, did anyone take a pic?
    Don't let it get you down, but there's a good chance you were an accident.
    2017 SC 5010
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by ForrestJones View Post
    We would have been fired on the spot. He was not happy; but we all enjoyed it very much.
    The Original Suspect
    Reputation: HitmenOnlyInc's Avatar
    Gorilla ghetto here with 2Bliss ready tires and Stan's valves and sealant. Works every time and zero issues. Sealant, tape and valves = About $35. I have also used valves from cut down tubes but they don't seem to work as good. Tires are gonna be the most expensive part of the equation. I guess my point is you do not need to spend the $60 for a Stan's kit.
    since 4/10/2009
    Reputation: Harold's Avatar
    I have UST rims and have tried semi-ghetto with regular tires as well as going full UST. full UST is WAY more reliable. I had so many burps, and was unhappy with the rapid air loss in the ghetto tubeless tire that I just tossed a tube into it. The UST tire has been worry-free. it holds air just as long as tubes do, and I haven't had a single burp.
    UST tires do have a stiffer sidewall, and I find that I do like the way that feels compared to the ghetto tubeless regular tire.
    I may try TR tires the next time I buy tires, though. performance should be better than ghetto tubeless regular tires, and curious how they will differ from UST.
    I have had very poor luck with standard WTB tires and sealant. As I have said before, Stan's ate away at the casing in WTB Velociraptors. I later found out that this is a known problem with standard WTB tires. It was at that time that I switched to 2Bliss. Yes, the Specialized branded. Great tires and I have never had a burp and I run about 23 lbs in front and 26 lbs rear. Also, They hold pressure extremely well. Even though I check pressure every time I ride, I rarely need to add more than a pound or two if it's been a few days.
    Quote Originally Posted by HitmenOnlyInc View Post
    Is this 2bliss on a non ust rim? I have regualr non Tubeless runs and have been doing ghetto Tubeless for a while without problems but want to try out those 2bliss. I like a couple of their tread patterns.
    Quote Originally Posted by kikoraa View Post
    Yes, DT Swiss 445 D rims. I have even run them on 12 yr old Mavic...not sure of the model #. They have a great warranty also.
    i was on wtb rim with gorrila tape, wtb wolverine tire and ardent and stan. only 1 prolem for almost 2 yrs, because i put about 25psi maybe less on front tire (wolverine race version with thin sidewall), the tire blew off the rim with 1 foot jump, I kissed the ground pretty hard.
    Lesson learned, no more low pressure on race version tire due to thin sidewalls.
    Now I have stan arch wheelset, with ardent and ground control, gorilla tape and stan. the valves from old tube. The tires are not tubeless ready (i think), but work fine. I put 32-35ish psi on rear and 30ish psi on front. I do little jump / drop 2-3 ft, no burping issue, so far.
    Reputation: 702Biff's Avatar
    Dec 2012
    Quote Originally Posted by huffster View Post
    ADVICE: When riding out at Bue Diamond, stay on the pavement until you hit the trail. There are A LOT of nasty thorns at the side of the pavement out there. Over a few days I got five flats until I figured it out (I'm kinda slow). Also check inside of tire to clear any that remain before replacing tube.
    'Tis but a scratch
    Quote Originally Posted by 702Biff View Post
    2 of our 3 flats were indeed the result of thorn pricks. My bro crashed and even took a thorn right through his finger (pain). 1 tube was flat instantly, while the other lasted another 15 minutes. The 3rd was unrelated - on my bike. Anyway, thorn = small hole...isn't that what slime is supposed to fill? <Rhetorical question.
    Dec 2012
    You would think, huh? I know it works well in my hand dolley wheels! I bought the extra thick tubes with slime hoping that will help.
