Results 1 to 35 of 35
    New question here. Should I listen to the LBS?
    Here is the story: I read the basic cleaning manual on how to clean the chain and cassette, so I called my LBS to see if they carry them, they said yes. So, I went into my LBS and asked for a SRAM power link. The sales guy said he had to go talk to the mechanic. I thought ok they keep them in the back where the shop is. He then comes back and tells me they don't use them they use the links from the chain. I then explain to him what I wanted to do and he said "don't do that you don't need to or want to break the chain to clean it. All you have to do is spray it with a little degreaser and rub the chain with a brush".
    However, I tried this before I even went to the shop an I still feel and see dirt and grit on the chain because of the thick and gunky factory grease that is still on the chain some what.
    So, my question is should I listen the LBS and try that again or should buy the power link and break the chain in order the use the mineral spirits in a jar method?
    Thanks in advance for the help.
    Well, I've done this with my BMX bike a few years ago, although it was still a bit sandy. You might want to break one of the links (it'll be a pain in the butt to put it back together though so be ready) then place the chain onto a clean surface where it's dust/dirt/pavement-free. Preferably a table or something. Get a white cloth and use the degreaser, spray it on the chain, and brush the chain. Afterwards, wipe it with the towel. You might want to put some time into cleaning the chain though. Took me a full day to clean the chain and make it look clean + dirt-free.
    spec4life???..smh...
    Reputation: spec4life's Avatar
    There is no doubt that the chain is much easier to clean off the bike not to mention you can do a much better job. I have a missing link on my chain, same as powerlink, and i love it. I wouldnt have another cahin without it. It easily comes apart and then you can pull the chain right off and get it spotless.
    I dont think you would regret getting one...
    Quote Originally Posted by spec4life
    Are you talking about the master link? If you are, yes that's an alternative to opening up the chain without the use of the chain breaker. But again, if you're not careful with the master link, it can break from time to time.
    No KMC chains come with a missing link that works like the power link.
    Thanks for the replies guys.
    Yeah that is what I thought when I read the cleaning guide it sounded easy, quick and effective. However, I have read post on here from both people that love them and hate them so when the LBS guy freaked when I told him what I wanted to do it made me question the idea. I guess it was just because he wanted to sell me their Park cleaning brushes instead of me buying a $3.99 link. Any more opinions, thoughts or comments will greatly be appreciated.
    Thanks.
    responsible zombie owner
    Reputation: Qatarbhoy's Avatar
    I've never taken a chain off to clean it. I apply degreaser and wipe with a rag, then apply Ice Wax or Dry Lube. I don't like to break stuff intentionally but admittedly I'm mechanically challenged.
    Five is right out
    I don't think the LBS was trying to rip you off. There are lots of different opinions on how to clean a chain, and people tend to be very vocal about the one they think is best.
    I prefer the Powerlink + jar method. It's easy and thorough. Others prefer the chain-mounted brush approach. I think the 'wipe with rag' method would be quite ineffective as it isn't going to clean *inside* the chain.
    I forgot to add I'm also lazy. But I've had no issues with dirty chains.
    Reputation: agabriel's Avatar
    I don't take my chain off to clean it, if its greasy it gets degreasier and a toothbrush. This has worked well for me. I have recently switched to a dry lube and my chain stays alot cleanier and my bike shifts better - depending on where you ride you might have a similar experience.
    Anthony
    ~I Ride In Circles ~
    Reputation: ZoSoSwiM's Avatar
    Dec 2005
    Powerlink fan here!
    I take my chain off routinely to soak it. Works well.. After cleaning with degreaser I rinse well.. then soak in rubbing alcohol to remove the degreaser entirely. My lube sticks well and the chain stays cleaner longer.
    ~ it's all good ~
    Reputation: sweetfilly7's Avatar
    I got one of the Park Tool chain cleaner tools, and I love it. You just snap it on over the chain, while still on the bike, sqirt some degreaser in there, turn the crank a few times and the chain is shiny and clean. Sooo simple, sooo easy. (and kinda fun too, in a weird way)
    +1 for the Chain gang- park tool cleaning device. Got one for my birthday and its great...and Fun
    Darn another Root...Pedal, pedal, pedal.....
    Ride the dream
    Reputation: EnglishT's Avatar
    Im gonna buck the trend now... and say that I would never use degreaser on my chains (anymore).
    I used to... but - chains seem to die quicker (and need more lube to keep them working right) when you clean them with degreaser.
    When you use degreaser it has a habit of getting right in deep into your chain, and is very hard to get out again. The result is that when you apply grease, it cant get deep in where its needed, because the degreaser is still there and gets rid of it.
    As a result - when degreasing your chain, you either have to spend alot of time getting the degreaser off (hard, and still difficult to get ALL of it off), or you leave it behind and have to add alot more grease on for alot less benefit.
    I guess what im trying to say (through tonights beer) is that chains, for me, last longer by just cleaning off the old grease (with rag) and applying new grease than if I degrease it and put new on.
    My current chain has lasted me 6 months already (personal record - im nasty to chains) without degreaser - which blitzes any regularly degreased chain I ever had.
    (It could be because this is my first KMC chain, prev used SRAM, but I think its more down to the way I look after it).
    Canuckistan
    I personally clean my chain weekly by breaking the chain, immersing it in a parts bath, and scrubbing the heck out of it....Then...I wash my chain off with hot water in the sink to get rid of the parts cleaning fluid...after which, I take my air compressor and blow 120psi air at the chain to get the water out....after all that is done, I lube my chain with teflon lube, and wipe the excess off.
    All totaled, it takes me about 20 mins to clean my chain. My chains tend to last on average a full season, unless I twist them in a crash.
    I have a shimano 9 speed chain, and I just grab a bunch of new chain pins from work every so often.
    MTB Addict
    I pull mine if it gets really gunky. Ordinarily, I just wipe it clean, soak it in pro-link, let it sit for a minute, wipe it clean again (sometimes I'll do it twice if it's still dirty, or 3-5 times to get the factory lube off a new chain). It seems to get a good bit of stuff out of there.
    To get an idea of just how effective it is to clean a chain off the bike, try cleaning it on the bike. Then take it off, put it in a bottle of hot water with some degreaser, and shake and let it sit for a bit. Then you'll see just how more effective taking it off the chain will be.
    I'm a big fan of the Powerlink - you'd be surprised how much junk is stuck deep within the chain that you can't get to even with spraying the chain down with degreaser and wiping it down with a rag.
    Bearded highlighter
    How long should a chain last?
    mine is going on almost a year now but I dont know what to look for as wear and tear of my chain.
    Canuckistan
    in terms of length of life of a chain, I would go, and get a $12 chain stretch tool from Parktool. once your chain has stretched to 0.75% or more, its time to replace it. Also, if your chain starts to get rusty, I would replace it....but thats a sign your chain isnt sufficiently lubricated
    i've only ever changed a chain once in 4 years, after i twisted a link changing gears with too much enthusiasm. it helps that i don't ride in mud and it only rains about 1 week a year here but on the other paw there's loads of sand dust and other grit around.
    good to see EnglishT also favours the old rag method. you don't necessarily want to strip all the greasy goodness out of a chain IMO.
    CrazyCanuck, are you joking about your 20 minute chain cleaning routine? it reminded me of Sheldon Brown's April Fool joke about proper chain cleaning!
    Canuckistan
    Im not kidding about my whole cleaning routine, only...though, truthfully the chain isnt the only thing that gets cleaned in that 20 minutes, both derailleurs come off, and so do my cranks, as well as my cassette. Reason being, is I live and ride in a very harsh environment for bikes. When its not muddy, its sandy.
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    There's different preferences and conditions.
    I've been running a SRAM Power Link on Shimano chains for singlespeeding and it seems to work well. I am usually too lazy to take the chain off, except for replacement, though.
    My usual chain maintenance is applying some spray lube and wiping with a rag. If the chain is really messy, I take out the degreaser (some cheap stuff for washing car engines). The SS bike gets it via a toothbrush, with the gearie bike I use one of those chain scrubber devices. Flush the degreaser out with water before lubing.
    Some say that frequent lubrication only helps in migrating all the gunk into the internal surfaces of the chain...
    Quote Originally Posted by CrazyCanuck
    Wow, good effort. Respect due!
    Here, when it's not sandy, it's dusty. The sand is on the ground and the dust is in the air but it's always there. Steel bikes rust in minutes.
    I've had very good results using a chain cleaner tool:
    http://www.parktool.com/products/det...at=5&item=CM-5
    http://www.mec.ca/Products/product_d...=1217172451335
    They last a long time and the brushes are replaceable in most of them (though I've never worn out a set).
    Probably not as good as leaving a chain soaking in degreaser overnight but they do seem to work quite well.
    Reputation: GuruAtma's Avatar
    The Park chain cleaner is perfect for normal cleanings. I just use dish soap (as recommended by Park). Only if the chain is really super gunky do I take it off.
    功夫大师喜欢骑着他的自行车在山上。
    what is this 'soap'?
    Quote Originally Posted by Qatarbhoy
    same stuff you use to wash dishes.
    功夫大师喜欢骑着他的自行车在山上。
    It makes sense that degreaser imbedded in the chain will break down new oil that's applied, contributing to wear and tear.
    Does this also apply to citrus-based degreasers? They're water soluble, and I rinse it off really well, then let dry before lubing.
    It would seem the only way to know for sure is to keep very careful records regarding chain life as well as gear life. I've had chains last for years, only to find out that I destroyed my gears in the process.
    My current plan is to keep my chain clean as best I can, and replace yearly. Hopefully I'll get better life out of my gears.
    Rod
    Rod is offline
    Reputation: Rod's Avatar
    Oct 2007
    I'm not a fan of power links. I've had 2 fall out on me in two years. One time it could have been my mistake, but I cannot imagine how I installed it improperly, but it fell out after a very rough section of trail with some drops. The 2nd time happened earlier this season the day before a race when I crossed a very high log. I went to pedal and the chain broke at the power link. The power link broke or it just fell out. It wasn't installed recently before the 2nd break. This is unusual because the owner of my lbs has never had it happen to him in many years, but I've had one friend lose a powerlink on a road bike.
    I clean my chain a little differently than other people, but it works for me. After I wash my bike, if it needs it, I wipe the dirt off the chain with a tooth brush and apply lube. It's simple and it keeps the chain clean. If it's nasty I'll take it apart at the power link and then degrease it, but I've only had to do that once.
    There is not much choice between rotten apples.
    Thanks for all the replies guys.
    To update: I went back to the same LBS and talked to one of the guys who runs the store. I told him what I was thinking about doing and he said that he has been doing the same thing except he uses gasoline as a degreaser to soak the chain, for years and has had no problems. He did recommend that I use a replacement master pin instead of the powerlink because I have a Shimano chain. He said the the powerlink would work but the master link would give smoother and quitter shifting. So I bought the master pin, removed my chain and soaked it in some mineral spirits. The result is a squeaky clean chain that is ready for a nice coating of the white lightning dry wax lube I have.
    Thanks for all the tips and comments this site rocks!
    Killer b.
    Reputation: The Understater's Avatar
    Generally, I've found it doesn't pay to clean your chain too often unless you can be bothered doing a really good job of it. It is too easy to wash out the grease and leave the grit behind. I only clean mine when it gets too much gunk build up on it or it gets rusty on the side links from wet conditions.
    I've used missing links for years with no problems and I think I probably have the most elaborate chain cleaning method of anyone here.
    First I remove the chain and drop it in a jar of cheap department store engine degreaser diluted with water, and put that in a heated ultrasonic tank for 20min to half an hour. Then I take it out and rinse in water before blowing air from the compressor through all the links to remove moisture. Then I throw it in a Lyman Turbo Tumbler filled with a mixture of ceramic chips, smashed corn cob, and molybdenum disulpphide powder. An hour of so in this and the chain is absolutely clean and dry, rust free, and full of dry-lube right down inside the rollers. I chuck it back on the bike, add whatever lube I am using, and away I go.
    Obviously I wouldn't go out and buy all this stuff just to clean my chain, but it is nice to have it when I do have to.
    Posting on the basis that ignorance shared is ignorance doubled.
    Quote Originally Posted by GuruAtma
    i only have a bowl, and i usually lick it clean.
    bshallard, you sound like the kind of guy who has some handy tips on disposing of bodies...
    For what it's worth, you can't go wrong with the advice of Sheldon Brown (R.I.P.) on all issues bike related.
    http://sheldonbrown.com/chains.html
    Killer b.
    No, that's my wife. She has a degree in forensics. I think she's probably capable of pulling off the perfect crime. What a woman!
    in that case i hope you bring her flowers and chocolates on a regular basis.
