Results 1 to 10 of 10
    Reputation: Norco_Ignite's Avatar
    Should I chose coil spring or air shock?
    I have a Norco ignite and i am buying a new rear shock. Should I go for the coil spring or the air shock? Thanks
    Reputation: splattered's Avatar
    both coil and air can give you a smooth ride, with air you can fine tune it to your weight with a HP pump, with coil you would have to specify what size spring you want, and possibly have a lbs order you a new one if it's too light or heavy, but with a coil if the internal seals rupture you still have the spring keeping the bike up with air your ride is done until you have it rebuilt,
    something to think about
    live life like a bullet
    FAST HARD AND GO OUT WITH A BANG
    Single(Pivot)and Happy
    Reputation: Boulder Pilot's Avatar
    Isn't the Ignite a hardtail?
    The suspension of your bike sucks if it's different than mine. Really. It sucks. Big time.
    The later Ignites are hardtails but the 2002 is dual suspension.
    http://www.bikepedia.com/Quickbike/B...nite&Type=bike There it is.
    I just got my Fox Shock Vanilla RC 8.5" i2i
    Here is the new shock. I didn't mean to put the old picture on.
    It depends on how much adjustability you want. With that big ass bike you aren't looking to save weight. If you don't really mess with your shocks a lot, (most people don't) I would go coil. I have air front and back, and it's a pain sometimes. I never had to mess with my coil sprungs.
    K I got a coil spring. It works good but the spring is to heavy for me. What lbs. spring do you think should fit me? The one I have is a 550lbs. spring. I weigh 110lbs.
    Card-carrying wotmeister
    Reputation: rabidweasel999's Avatar
    Probably a 450. I'm 120lbs and that's what I ride.
    Yea thats what I was looking at on ebay either a 450 or 400.
