Results 1 to 3 of 3
    Aug 2013
    Should i attempt to replace BB ?
    My sons 2012 B-Twin Rockrider 8.1 mtb has play in the Shimano Deore M590 22x32x44 crankset.The BB is Shimano BB51 Deore Outboard Bearing Bottom Bracket Set which only costs 10. He took it to the LBS and was quoted 25 to replace it but theres a 10 day wait. I've never attempted to replace a BB before. Would you advise we do it ourselves and pay out for the tools ( how much and what tools are essential ) or do we save ourselves the hassle and pay the LBS although i would rather do it ourselves as its good to know these things.
    Reputation: mitzikatzi's Avatar
    Decide yourself. I can't link to the Park tools site at the moment.
    Workshop: Replacing Shimano, Truvativ or FSA bottom brackets a little confusing they explain how to to two types of cranksets but it gives you the idea.
    X-Tools BB Tool Hollowtech II - Spanner Fitting
    Shimano Deore Bottom Bracket Set BB51
    Duct tape iz like teh Force. It has a Lite side and a Dark side and it holdz the Universe together.
    If the play is side to side have you tried tightening the crankset? Loosen the pinch bolts on the non drive side. Use a 6" C clamp and 2 paint sticks as scratch protection to get a little pressure on the assembly and retighten. You can also clean and grease the bearings. Use the middle of a thin blade knife to pry lightly around the outer edge of the plastic cover and the inner edge of the bearing cover to get access. New bearings often are missing enough grease on the non drive side.
  1. First Attempt
    By All_talk in forum Videos and POV Cameras
    Last Post: 04-16-2013, 01:05 PM
  2. My first attempt
    By Mustardpig in forum General Discussion
    Last Post: 01-27-2013, 07:40 AM
  3. maintenance: chain replace vs. drivetrain replace
    By mortenc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-23-2011, 04:25 PM
  4. my first pic attempt
    By rockcrusher in forum Frame Building
    Last Post: 11-05-2011, 07:58 PM
  5. My 1st attempt at a non-POV
    By tex540 in forum Videos and POV Cameras
    Last Post: 08-25-2011, 12:05 PM
