Thread: Shimano SM-RT81
    Sep 2012
    Shimano SM-RT81
    Hello,
    if anyone is using on his bike the shimano SM-RT81 rotors, i would like some suggestions and advice. I use the XT brakes with F01A resin pads and i was thinking about putting on these rotors (180/180) for better cooling and performance. Any thoughts ? I have seen the SM-RT86, too, which are a bit less expensive, but i cant understand their difference.
    Thx
    MTB B'dos
    Reputation: LyNx's Avatar
    Look at them carefully, I think it'll come to you. Would also help if you read the desription, that could also help
    RT81
    RT86
    Sep 2012
    Quote Originally Posted by ins@ne View Post
    Hello,
    Thx
    Which one you use depends on your wheel hub. If it is a Shimano centerlock hub, then use the RT81 rotors. If it's a standard 6-bolt disc hub, the RT86 is the one you need.
    -S
    Sep 2012
    thanks! i have the Shimano Deore XT HB-M785 hubs. And from what i saw they come with centerlock hub, so i am gonna use the RT81
