Results 1 to 10 of 10
    Sep 2013
    Shimano SLX Crankset - is 9 and 10 compatible
    Currently I own a 9 gear (Megadrive) crankset FC M660 SLX 44-32-22.
    I am wondering can I install it in a bike with a 10 gear (Dynasys) system? Is it compatible? Or do you I have to change the cogs?
    I remember when I was buying the 9 gear crankset the sales guy said it doesnt really matter if I buy the Dynasys / Megadrive but I didn't really believe him...
    Reputation: 006_007's Avatar
    Yes, it will work just fine.
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    Quote Originally Posted by 006_007 View Post
    006_007 is right. I ran a FC-665 SLX double with SLX 10 spd dynasys working as the rear half of my drivetrain. It worked well, but I am running 1x10 now.
    I just measured a SLX 9 speed triple and last years and this years(13) SLX triples with a caliper and they are the same.
    And of course the chain ring gear tooth width is the same because the chain roller width is the same only the side plates are thinner for 10 speed chains.
    Jan 2013
    Quote Originally Posted by KrzysztofMTB View Post
    Yep it is, you should be fine!
    Sep 2013
    So the 3x9 and 3x10 crankset is compatible? good news! I wonder why 3x9 has 44/32/22 and 3x10 has 42/34/24?
    I think the reason given was because of the cassette going to not only ten speeds but also to a 36 tooth big cog. I guess it gives a more workable range without a lot of overlap.
    Had everything to do with the 9sp used a 11-34 cassette, and the 10sp stuff is typically a 11-36. I actually prefer the 22T on 650b bikes (I find bigger wheels slightly harder to spin up and appreciate the slightly easier gearing).
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I have used mega-drive (9 speed) chainrings on an SLX crankset with a 10 speed drivetrain. Worked perfectly.
    Competent User
    Reputation: Mr.Quint's Avatar
    Mar 2012
    I have a 9sp SLX m665 crank and a 10sp SLX rear. No problems.
  1. Is this crankset 10 speed compatible?
    By jarango in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-23-2013, 07:27 AM
  2. Compatible Shimano shifters for Shimano Alivio, please help
    By jd81 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-16-2013, 08:46 AM
  3. Shimano LX Crankset compatible with 10 spd Chain?
    By megalops in forum All Mountain
    Last Post: 06-29-2011, 04:26 PM
  4. Lightest crankset compatible with XX chainrings?
    By fueledbymetal in forum Weight Weenies
    Last Post: 03-20-2011, 09:49 AM
  5. Shimano pressfit BB - Which crankset are compatible?
    By xtremgirl in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-08-2011, 06:19 PM
