Results 1 to 18 of 18
    Jun 2014
    Shimano Altus + Schwalbe Big Apple 28x2.35 on Trek X-Caliber is a nogo?
    Hello.
    I have Trek X-Caliber 7 bike and I wanted to switch bit more tarmac friendly tyres on it, Schwalbe Big Apple 28x2.35.
    X-Caliber 7 - Trek Bicycle
    Front derailleur is Shimano Altus. Problem is that BA is grinding on Altus especially middle and smallest chain ring. On biggest ring there is no problem. Here is a few pictures.
    On biggest chain ring
    Front derailleur is top swing. I have looked another derailleur that could be little different (compact) mechanism.
    Product
    Do I need to change front derailleur (to SLX?) or what I can do to fit those lovely tyres? I tried to lower front derailleur, but it didnīt help.
    And sorry for misspelling, I think you can understand
    Hmm.. Well, you can being it to an lbs and see if they have any laying around that you can try to see if it'll fit. But moving the derailleur up or down is not a good idea it has to be at a certain height. Or hit it with a hammer a whole bunch lol
    Sent from my SPH-L710 using Tapatalk
    B A N N E D
    Clearance is probably the reason that the bike came with a 2.20" front tire and 2.0" rear tire.
    Fat-tired Roadie
    Nov 2007
    I'd probably just use a smaller rear tire. Post the year and wheel size so if someone is wondering about clearance and hasn't bought yet, maybe you save them the trouble.
    I've read that SRAM front derailleurs have better tire clearance. Also an E-type derailleur would probably provide more tire clearance. Not sure how easy it would be to fit.
    29ers Forever
    Reputation: CannondaleF9's Avatar
    Nov 2012
    If you want a "tarmac friendly" tire, you had a good choice by going slick, but you never go wider. You should have found a 2.0 tire or something like that.
    Jun 2014
    Quote Originally Posted by cobba View Post
    Maybe yes. I must change tyres back to Bontager and see how small tire clearance is.
    Quote Originally Posted by AndrwSwitch View Post
    But I wanted to fat tires, just the looks of it Trek X-Caliber 7 is 2014 model and I think those Big Apple 28x2.35 tires are also from this year. Or at least I bought them week a go from bike-components.com.
    Quote Originally Posted by Slash5 View Post
    I must check those. But because Iīm noob in bike tech, could I use SRAM front derailleur and Shimano SLX M662 SGS in rear (yes I have stock Acera at the moment in rear, but it got slightly damaged by tree branch).
    Quote Originally Posted by CannondaleF9 View Post
    I have also Kenda Khan 28x1.9 if I remember those dimensions right. Those are quite nice, but I just wanted fatter tires just for looks
    I have also noticed that there is only minor difference in time when going to work (13km/8.07miles) when tires are Bontager XR1 or Kenda Khan. Itīs only slightly heavier to pedal with Bontager. But Kendaīs are much comfort, because there is no need to higher pressure comparing Bontager. I wonder that is BA 28x2.0 diameter smaller than BA 28x2.35?
    Fat-tired Roadie
    Nov 2007
    Pressure and volume are pretty linked.
    If you're willing to buy a new front derailleur in order to keep your fat tire, yeah, SRAM 9-speed or fewer should drop right in. You still need to match swing, cable pull, and clamp size.
    Another thing to look at is if you can switch to a bottom swing front derailleur. They have better clearance and I could swear they tolerate dirt better. Look for bottle cage mounts or a change in seat tube diameter to interfere with that.
    Jun 2014
    Yes, I was thinking about upgrade Shimano Altus at the same time. Even tough there is nothing wrong in Altus, it has worked great.
    I have not seen in a long time bottom swing FD. Itīs weird that it could have better tire clearance.
    I have looked few FD, what you think about these?
    Shimano SLX M661
    Product
    Shimano SLX M660
    Product
    SRAM X9 9 speed low clamp front mech
    SRAM X9 9 Speed Low Clamp Front Mech | Chain Reaction Cycles
    SRAM X9 speed high clamp front mech
    SRAM X9 9 Speed High Clamp Front Mech | Chain Reaction Cycles
    Trek has 34,9mm tube diameter and cable comes from top.
    Itīs a shame that there is enough pictures about FDīs. Especially how big is the mechanism near the tire.
    Fat-tired Roadie
    Nov 2007
    I like Shimano's front derailleurs better. I think they "get it" more.
    Look at some pics of bottom swing/high clamp FDs. I think it'll be pretty apparent to you why you might get better clearance.
    Drop into your LBS and take a look at other MTBs, see what design give the best clearance.
    I would be surprised to find a front derailleur that would clear a 2.3" Big Apple. I have a Surly Ogre with those tires and a Shimano Deore FD-M616 top pull derailleur and I had to use Monkey Nuts to push my wheel back in the dropouts to clear the tire. But your frame doesn't have horizontal dropouts. Maybe sell the rear tire and get a 2.0" Big Apple?
    RAKC
    Reputation: tigris99's Avatar
    Trek 29er hardtails are good for that. Biggest I have been able to fit is a 2.2 but it wasnt terribly high volume, Kenda Karma. It was pretty close though with the knobs.
    Front FD change may work but your clearance is already horrible so not sure if the change will be enough.
    I get you like the look but if bike isnt built for it, only thing you can do is go smaller unless you want to start messing with new parts that may or may work. Good luck hope you get it sorted.
    Jun 2014
    Yes I realize that it could be risky to buy FD, because you canīt be sure that it will leave enough clearance. I might sell rear tire and buy 2.0" wide. Or sell both and buy new set of 2.0"īs. I have to think about what to do next. In meantime I will ride Kenda Khan tires my commute trips.
    Thank you all for the answers. Iīm really grateful!
    Fat-tired Roadie
    Nov 2007
    You probably don't have to back off all the way to a 2.0. This is a mountain bike and 2.1 was standard for ages. If you can test fit next time (big "if," I know,) that would really let you know.
    Or be a total fashion victim and go 1x.
    Well, 2.0" Big Apple is going to be bigger than a usual 2.0.
    Jun 2014
    I did go the easy way for this problem. I bought new set of BA 28x2.15 tires. I found some dimensions of these tires from here Balloonbikes - technology and I measured my other tires and compared them to BA 28x2.35. My Kenda Khan 1.9 tires has almost same diameter as BA 28x2.15 so there is now same amount of space.
    Next is BA test run
    Mar 2015
    have a 2014 Kona Kahuna came stock with Maxxis Ikon 2.2 tires didn't think I could fit the 2.35 big apples so went with a 2.15 I have about 5 millimeters of clearance between the tire and the front derailleur think the two 0.35 would fit
  1. Schwalbe Big Apple 29r Tire
    By Butanman in forum 29er Components
    Last Post: 10-11-2015, 11:57 PM
  2. JUST IN : Schwalbe Super Moto 28x2.35 676/685g
    By Cloxxki in forum 29er Components
    Last Post: 01-30-2015, 06:14 PM
  3. schwalbe big apple owners....
    By johnny the boy in forum Surly
    Last Post: 10-25-2014, 09:37 PM
  4. HELP!!!PLS. i need help with my shimano altus shifters.
    By TheMajorMTB in forum Beginner's Corner
    Last Post: 06-01-2014, 08:59 PM
  5. Schwalbe Big Apple
    By Vandals909 in forum 29er Components
    Last Post: 11-09-2012, 08:32 AM
