Results 1 to 7 of 7
    Reputation: TuCsaT's Avatar
    Shimano 7 speed shifter on 6 speed?
    I'm going to preempt any "it's not even worth fixing, get a better bike" with I am currently in Afghanistan and while I have several nice hardtails at home all I have here is an old mountain bike that has Shimano tourney parts. The rear shifter is broken and I'm trying to find replacement parts. I was able to find the exact parts from a third party seller on amazon Amazon.com: Shimano Shifters SL-TX30 Tourney 3x7 Pair: Sports & Outdoors
    but I am interested in seeing if I can actually upgrade to a better trigger shifter.
    The rear derailleur is a Shimano Tourney with a six speed cassette and it appears to allow for indexed shifting. Can I use a different shifter such as a 7 speed? They seem reasonable and easy to find and would actually prefer them.
    I know this is kind of a weird post but I've gotta make do with what I have over here.
    Thanks in advance,
    Paul
    If only Sikorsky made bikes...
    You would need to either add a 7 speed cassette or use 7 speed spacers on the current 6 speed cassette.
    Are you sure it's a cassette? Many 6 speeds are freewheel. The derailleur should work fine.
    Shimano Cassettes & Freehubs
    Quote Originally Posted by Slash5 View Post
    Thanks for the help. I guess I'll just try to get a six speed shifter. This bike really isn't worth spending much money on and it looks like I would need to buy new gearing, chain and the shifter.
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    You could always try a friction shifter, they're usually pretty cheap. Or go visit your local bike shops and see what they have in their take-off bin. If they have an old 6 speed around, they would probably sell it cheap.
    What kind of shifter is currently on the bike? I've made 8s shifters work with a 7s freewheel before. A 6s shifter would be ideal, but the 7s you linked could work for you if that's all you can get. You would just have one dead click on the shifter where you would click from 7 to 6 and nothing would happen.
    Picture Unrelated
    Jun 2005
    Quote Originally Posted by owensjs View Post
    The spacing for 7 and 8 speed is the same which is why you can use an 8 spd shifter with a 7 speed cassette (but you don't get a "dead" click because you adjust your limits, right?). The spacing for 6 speed is different to 7/8 speed and, while I haven't done it, I would suspect that it will not work well. I suppose if you're happy enough with a few gears in the middle working and not being able to shift into the extreme ranges, it might be serviceable though. Here's a chart: Sheldon Brown's Bicycle Frame and Cassette Spacing Crib Sheet
    Quote Originally Posted by zebrahum View Post
    Yeah good point on that. It slipped my mind to think about the spacing being different between 6 and 7s. If the 7s shifters are all the OP has access to, it might be worth at least trying. 6s or even friction would be the best way to go.
  1. XO Twister 10 speed shifter mod/ Shimano Excellent
    By rjedoaks in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-10-2016, 12:34 PM
  2. Help finding the right Shimano Ispec 2 speed shifter
    By Sleevem1 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-20-2012, 07:38 PM
  3. 1990s Shimano 8 speed XT shifter replacement
    By brudermtb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-25-2012, 10:27 PM
  4. Shimano XT 10 speed shifter problem
    By Mauri in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-10-2012, 10:11 PM
  5. Does Shimano make a 2012 XT 9-Speed Shifter?
    By estabro in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-20-2011, 07:06 PM
