    Setting up the new Bike Computer
    Hey guys, first off I just wanted to say this has so far been a great source for information for my new hobby. The forum is nice and full of great info.....
    I just got a Cateye Velo 8, and it's super easy to install, no problems there, the thing that is confusing me is the full wheel configuration on the unit. I have read the instruction manual a few time, and have not been able to understand everything from the pictures.
    This is the link to the manual
    http://www.cateye.com/sites/cateye/u...810_ENG+v3.pdf
    I have a Specialized Hard Rock Sport Disc, which from the specs has wheel base of 1109mm and 26"x2" wheels/tires. What should my settings be? Or rather what are all these variables on the Velo 8?
    26->700c -> 27 -> [205] -> 16 -> 18 -> 20 -> 22 -> 24
    I know 26" is the tire size, the 205 according to the manual is 26 x 1.95 but what are the rest of the numbers for? And if I have 26 x 2, then is 206 enough data to input into the Velo 8? Do I need to be concerned with the 700c, 27, 16, 18, 20, 22, 24 values?
    Reputation: wave180's Avatar
    May 2010
    Just set it at 206, since it's equivalent to your current tire size.
    Right but what are all the other values? I guess they don't matter, thanks I'll give it a try and see how accurate it is. I just thought all those values have to be set for the best accuracy, except I am not sure what all those values are....
    May 2005
    Those are all just tires sizes. The 205 or 206 or 216 appears to be the tire circumference in cm, according to the manual. The typical way to find this would be to inflate the tire to the pressure you normally run, make a mark on the side of the tire and the ground, roll the bike forward one full revolution of the tire using the mark you made on the side, make another mark on the ground, measure and convert to cm. Or if you have a flexible tape measure or a cloth tape, just measure around the outside of the tire and convert to cm, and then input this number into the computer. Either way should get you close, or just go with the closest preset tire size.
    Gary J.
