1. The most important thing about buying a new bike is to make sure it fits. The only way you'll know if the bike is right for you is to size up the bike and make sure that the bike's geometry matches your body's geometry. Ask questions and do some research.
mtn. biking 101
2. If possible, try to find a shop that will let you demo the bike on real dirt. Five minutes in a parking lot won't cut it. You wouldn't buy a car without a real world test drive, and a bike should be no different.
3. Don't belive the hype. Just because your favorite rider or best friend rides a certain bike, that doesn't mean that's the best one for you. Have an open mind and be realistic about your needs and ability.
Results 1 to 6 of 6
Thread: Rutty hardtail
    May 2014
    Rutty hardtail
    I'm not really a beginner (nor an expert) but I ride am and there is one section that has a ton of ruts. A the few times I have gone over it the end of my bike likes to buck.
    Any suggestions one how to prevent this?
    is it a hard tail?
    edit
    Yoda says be one with the bike.It's all about picking lines, seeing the lines.Look as far forward as you can.
    May 2014
    Re: Rutty hardtail
    Quote Originally Posted by joel787 View Post
    is it a hard tail?
    edit
    Yep
    Picture Unrelated
    Reputation: zebrahum's Avatar
    Jun 2005
    Soft knees, soft hands, and just ride it out. Hardtails are going to jump around when the going gets rough, that's just what they do. You can also examine your tire pressure, make sure it's not too firm and you'll gain a little squish there too.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    Re: Rutty hardtail
    Get your butt off the saddle an inch or two and slightly shift your weight back. Loose elbows forearms and knees.
    The bike has no rear suspension to take the edge off so you need to become the suspension. Removing your butt from the saddle removes the bashing from your back and shoulders. Try to "float*
  1. 26 Hardtail
    By Sydney GL in forum Bike and Frame discussion
    Last Post: 03-09-2014, 09:08 AM
  2. Which hardtail?
    By vinisousa in forum Beginner's Corner
    Last Post: 03-07-2014, 10:47 AM
  3. Hardtail or not to hardtail - thoughts and advice please
    By Velosprocket in forum Specialized
    Last Post: 02-15-2014, 06:57 PM
  4. Hardtail to FS back to hardtail?
    By VTSession in forum All Mountain
    Last Post: 08-15-2012, 08:16 AM
