• 11-25-2012
    db_8
    RS recon silver R 2011 fork for '99 moab 2
    is it worth it? the '99 RS judy c that came with it isn't really smoothing out anything on the downhill and being lightweight at 120# isn't helping... i'm seeing less than 63mm of travel. pretty sure the frame will take 100mm travel at the most as the fork back then had an option for 80mm and so give or take 20mm from what i'm reading here.
    :confused:
    don't think saving up for a newer/second bike is an option right now. plus this bike is in near mint condition with pretty good components imho (XTR rear der, LX front der, XTR rear vbrake, deore hydros front m525 with deore XT disc hub). a pretty nice moab2 sounds really good to me, too. any help would be appreciated.
  • 11-26-2012
    eb1888
    The main problem you have with your current fork is going to need solving with any other partial coil spring fork. The spring needs to be matched to your weight to place its compression and rebound damping in the right range. On the Sram site under Service to Rockshox to 2013 Parts to Recon they list a Coil/Shaft Assy available in x-soft and soft. The weight ranges are something a Sram tech will have to help you determine. Order the part from a LBS and do the service. Your bike should see a major improvement. The air on this fork will let you set the sag
  • 11-26-2012
    mitchg
    I replaced a Judy XC on a '97 GT Avalanche with a 2012 Recon Silver Solo Air. I ran it for a week at 100mm but it handled terribly. I dropped it to 80mm travel and it's been great. It was definitely worth the change in my opinion.
  • 11-26-2012
    db_8
    I was thinking that, too! can't find the soft spring assembly for my current fork though. the manual is pretty vague on the spring parts and compatibility. it would be cheaper but still leave me with only preload adjustments. on the other hand, it'll be easy to find the matching spring for last year's fork at the cost of $$$. will do some more research.
    Thanks for sharing your experience :D Solo Air would be nice, no springs to change. I saw a really good deal on the coil version of it but without the Motion Control system at Pricepoint.
  • 11-26-2012
    shibiwan
    I think someone on this forum recently picked up an RS Recon Silver Solo Air for like $200 off Amazon... maybe check there.
    -S
  • 11-26-2012
    eb1888
    At your weight I'd do some actual test riding on a new bike with the fork you are interested in if you are thinking solo air. Make sure you get them to set the pressure down to your weight level. Otherwise the air platform will wipe out small bump compression. A dual air Reba or Manitou with Absolute+ and the small helper spring can be set up for you.
  • 11-26-2012
    db_8
    Would the spring rating affect the fork travel? Or just sag/preload? Any coil forks I assume would come with stock springs (medium).
  • 11-26-2012
    eb1888
    It affect the travel most noticeably over small to medium bumps. Not by limiting travel but creating a threshold before it moves much. The stock spring is probably a firm aimed at 175lb riders unless a bike is woman specific.
  • 11-26-2012
    db_8
    Seems like I'll be better off getting an air fork from the start seeing as switching out springs would pretty much be like a rebuild. Unless there's women specific forks being sold as opposed to a whole bike lol.
  • 11-26-2012
    hadeone
    -S
    I ended up refusing it and got the Manitou Minute Expert from CRC, which can still be had for $200 shipped.
    Amazon raised the price on the Recon SoloAir to ~$300.
    Everyone in my thread convinced me to go with the Manitou due to its highly superior damper.
  • 11-26-2012
    shibiwan
    Yes, an air-sprung fork is more versatile and would probably work better for you. It does require a little more care and maintenance.
    Hmm... I would have steered you away. Manitou's quality control is hit or miss... but then again that may have been their older stuff. The Manitou SX MRD on my old Klein Mantra is practically dead - all the fluid leaks out and it can't be rebuilt because the plastic bottom seal-nut completely disintegrated when I tried to take it off.
    I did just pick this up - waiting for it to arrive in a day or two:
    Rockshox Revelation XX WC Da Fork 2011 > Components > Forks > Suspension Forks | Jenson USA Online Bike Shop
    -S
  • 11-26-2012
    hadeone
    From what I've been reading the past couple of weeks, everyone on this forum is raving about the Manitou Minute, both Expert and Pro. Mainly about the Absolute+ damper. I have no experience yet so we shall see.
    That Rev fork you got seems great but I don't see myself spending that much for a fork yet.
  • 11-26-2012
    shibiwan
    I felt kinda guilty spending that sort of cash but I figured I'd make up for it by selling my old Talas so it works out.
  • 11-26-2012
    db_8
    lol same here. trying to not spend more than the price of the bike...
  • 11-27-2012
    mitchg
    I got my Recon Silver TK Solo Air for $175 before tax from Performance during summer. Just had to be patient.
  • 11-27-2012
    db_8
    wow good price! after researching, i've decided on the Recon Silver tk solo air also and will wait for deals this year-end. will keep track on pricepoint, CRC, performance bike and amazon. any other suggestion for shops to watch out for?
  • 11-27-2012
    hadeone
    Have you researched these threads? They helped me make my decision.
    http://forums.mtbr.com/beginners-cor...hi-819553.html
    http://forums.mtbr.com/beginners-cor...nt-712339.html
    http://forums.mtbr.com/shocks-suspen...rk-780364.html
    http://forums.mtbr.com/shocks-suspen...ir-822920.html
    I read thru a lot more but these are the ones I could recall, including the last one which I started, asking for help.
    Good luck.
  • 11-27-2012
    db_8
    thanks! yes i saw those threads, read through them too and helped me with the decision :) sorry if this thread seemed similar but my original question was regarding putting it on a '99 frame. found my answer and topic shifted to what type and which one. now it turned out to another fork thread lol sorry about that
  • 11-29-2012
    db_8
    saw this:
    Ben's Cycle Vendio Store
    is this site legit? pondering on getting this spring if so... and might grab the new updated seals, too
    SID®/JUDY®/PILOT® SEAL KIT
    would be significantly cheaper with a bit of work.
  • 12-04-2012
    db_8
    ordered the soft spring kit and new wiper/seal. will rebuild the fork and install these and see if it gets better then decide if i should still get better forks or just save up for a new bike :) i know a lot more stuff now and i think my riding style is all-mountain, no racing, don't mind climbing at my own pace and want to have fun and be smooth on the downhill but be able to take those technical parts. my current bike is more or less XC type but will try to work on converting it to all-mountain. i'm itching for full suspension but that's out of my reach right now.
