    Reputation: brderj's Avatar
    RockyMountain VP-135 DH Clipless
    My old Shimano pedals are crap now so I am out searching for a new pair. I found these by Rocky Mountain http://www.cambriabike.com/shopexd.asp?id=24907 but I know very little about them or the sizing. I thought all clipless fit the same, give or take that rare instance. Any help with these would be great and any reviews would be equally appreciated as there are none up at the time. Thanks.
    brderj
    Reputation: 006_007's Avatar
    Quote Originally Posted by brderj
    brderj
    I would happily take a pair of Shimano pedals over those ones any day. The Shimano SPD system is one of the best clipless systems available. Another one that is very highly rated is the crank brothers system.
    The Crank Brothers system sheds mud better, so if you ride in a wet environment then those could be a better option for you.
    As far as having a clipless pedal with a cage on it I would not bother. When you are clipped in you are not actually touching the cage, and most clipless shoes have a hard plastic sole that cant grip the cage when you are not clipped in anyhow.
    My $.02
    TJ
    Thanks TJ. I suppose I was under the impression that SPD were all the same. I was looking for the whole cage set up for stop and go riding. On top of riding my bike in the mountains, I will also be riding it on the street. Thanks for the help,
    brderj
    brderj
    For a street day/run to the corner store just pick up a set of cheap flat pedals. Takes less then 3 minutes to swap pedals.
