Results 1 to 8 of 8
    Mar 2014
    Rockshox xc30 - Lock out - Should the fork move at all when locked out?
    Hi not sure if anybody can help. I have just upgraded my forks to a Rockshox XC30 Fork. It has a lock out feature however when it is engaged If I put my full weight over the front of the bike when riding I can move the fork up and down with effort. To note I am about 180lbs in weight
    If I disengage it then the fork acts as you would expect - with suspension.
    I wasn't sure if the lock out feature is designed to completely prevent any movement (up and down) in the fork or if it just makes it extremely stiff ( as with mine?
    Many Thanks
    David
    since 4/10/2009
    Reputation: Harold's Avatar
    It will not make the fork completely rigid. There will be some movement.
    Mar 2014
    Many thanks - so basically I can bounce the fork suspension if I put my weight on it even when locked out - albeit I would have to be right over the bars with my weight and it is very stiff. Just wanted to check that there isn't a fault. I was under the impression it completely made the fork rigid. Thanks
    Reputation: mercyNside's Avatar
    Jan 2014
    Quote Originally Posted by davidhorder@aol.com View Post
    Many Thanks
    David
    Hi David,
    I have the same fork. When locked out mine moves slightly up and down as well. I'm around 170lbs... I've been told this is completely normal.
    2014 Cannondale Rush 2
    Mar 2014
    Many thanks. I was just surprised that even when locked out for example if I drop off a kerb and I happen to have my weight over the bars the fork will still move down. Basically to me it doesn't really lock out the fork but just makes it really stiff with movement still possible
    The TurnKey lockout feature on that fork has a blow off valve that's designed to allow the fork to compress during an unexpected hit. You dropping off a curb with the lockout engaged and the fork compressing is a prime example of this.
    XC 30 TK | SRAM
    Apr 2014
    glad someone else has this same issue, i just put a set on my full suss and its the same, if i really lean on them they move a bit when locked out.
    Reputation: lotusdriver's Avatar
    Sep 2013
    My Rock Shox Sektor is the same, when locked out it will still move a little.
  1. Help! Changing Spring on Rockshox XC30
    By ssorange in forum Shocks and Suspension
    Last Post: 05-14-2017, 12:10 PM
  2. Rockshox XC30 Gold to Reba?
    By thegock in forum Shocks and Suspension
    Last Post: 04-11-2014, 07:06 PM
  3. RockShox XC30 to Reba RL - Worthwhile upgrade?
    By spena in forum 29er Components
    Last Post: 03-07-2014, 07:01 AM
  4. Rockshox XC2 vs XC30?
    By mountainbiker118 in forum Shocks and Suspension
    Last Post: 07-27-2013, 09:42 AM
  5. rockshox xc30 click
    By antflec1990 in forum Shocks and Suspension
    Last Post: 07-03-2013, 02:52 PM
