Results 1 to 11 of 11
    Oct 2007
    RockShox Recon Silver TK Coil Forks w/9mm QR to 120mm?
    Hello group,
    Im putting together a bike for my wife and the frame specifies a 120mm fork with an 1 1/8" steerer. It is the 2011 GT Sensor, XS.
    Can the RockShox Recon Silver TK Coil Forks w/9mm QR and 1 1/8" steerer or the RockShox Recon Silver TK Solo Air Forks w/9mm QR 1 1/8" steerer be adjusted for 120mm travel? The RockShox website says these forks must use a 15mm Maxle and tapered steerer if adjusted to 120mm travel. Is this a safety or performance issue?
    Thanks, Will
    Feb 2013
    It's likely a safety issue for the steerer tube. Tapered steerer tubes are stronger than a straight steerer and it maybe necessary for a frame with a slacker headtube angle for a longer travel fork. As for the Maxle, I'm not sure why they want you to use one of those.
    The 9mm axle and the 15mm Maxle are two different fork specs. The 9mm is for a quick release wheel ,the 15mm is a though axle.
    Fat-tired Roadie
    Nov 2007
    Do you have the fork on hand or are you shopping for it?
    If you have it, it's more a question of whether it's a 120 mm fork that's been adjusted to 100. If the hardware's not long enough, nothing can increase the travel of the fork. RockShox forks can have travel reducing spacers installed. Hunt up the service manual for the fork, then crack it open and see if there's a spacer in there.
    If you're still shopping, just buy a fork that ships with the right spec.
    fly on the wall
    I don't know why RockShox claims you have to have a tapered steerer and thru axle for a 120mm fork, because if you look up pics of a 2011 Sensor, many show a RockShox 120mm fork with 1-1/8 straight steerer and 9mm quick release.
    Case in point: GT Sensor 2.0 - BikeRadar
    So I would cross off these as factors to worry about in finding a 120mm fork.
    ~Always avoid alliteration.
    Channel: http://www.youtube.com/user/NearlyFr...ew=0&flow=grid
    Oct 2007
    Thanks for your replies folks.
    As a result, I plan to purchase either a Recon Silver or XC32 fork and adjust for 120mm travel by removing the spacer. Or possibly have the supplier of the fork do it.
    Does anyone know if an Extra Small frame would require a shorter length of travel or a shorter overall length than the specified amount?
    Clueless genius
    The frame size will have no effect on the bike's travel. The smaller size means (basically) the toptube and seat tube are shorter to accommodate a smaller rider. Generally they have a shorter stem as well. The frame size in no way affects how much travel it has or is supposed to have. The Sensor is a 120mm (5 inch) travel bike, and should be specced accordingly.
    In a quick search on ebay I found pretty much exactly the fork you wanted initially for the bike, likely a take-off from that model: Mountain Bike Fork | eBay
    However, if you're willing to spend a bit more, there are plenty of other options out there. Also, if you haven't purchased wheels for the bike yet, I see no reason not to get ones that have a 15mm front hub or are adjustable between 9 and 15mm. Cost permitting of course. If you already have wheels, then disregard.
    1994 Cannondale M400 2017 Felt Surplus 30
    1997 Marin Point Reyes 2013 Pivot Mach 5.7
    Fat-tired Roadie
    Nov 2007
    Quote Originally Posted by willgreg21 View Post
    Do a little homework on this before you type in the credit card number. It's possible to build a 100 mm fork that can't be extended. I don't know if a RockShox fork that comes out of the box as a 100 mm fork is really a 100 mm fork, or a 120 mm fork with a travel reducing spacer.
    A while ago, Specialized released some women's bikes that had less travel in the smallest sizes. I haven't heard of anyone else doing it.
    Reputation: hOlykamOtie*'s Avatar
    I have the 2012 version of Rockshox Recon TK Solo Air and is adjustable from 80mm to 120mm by adjusting the PSI you put. I also have the Recon R which is similar to TK Coil except it doesn't have a lockout and it's set to 100mm and can't be adjusted externally. I am not sure if you can adjust it internally. Both are 1 1/8" QR 9mm
    Hope that helps!
    fly on the wall
    Quote Originally Posted by hOlykamOtie* View Post
    Hope that helps!
    Your first sentence about the travel vs psi is confusing me. Recons, as far as I know, don't have travel adjust like the Revelations, and even then it's by a switch, not based on air pressure. It sounds like your fork is already set at 120 and sagging to 80mm when it's low air. If you were to lift up the front of the bike when it's at 80, does the fork extend some more?
    Oct 2007
    Thanks again folks,
    Today I purchased a XC32 Solo Air. The seller has confirmed his fork can be converted to 120mm by removing a spacer and he is doing the conversion before shipment. Travel should increase to 120mm and Axle to Crown length should increase about 20mm. Thanks again for your help, Will
  1. Recon TK Silver 29 100mm to 120mm
    By tjwil9488 in forum Shocks and Suspension
    Last Post: 09-03-2013, 09:25 PM
  2. Replies: 8
    Last Post: 07-30-2012, 10:51 PM
  3. Recon Silver TK Coil OR XC 32 TK?
    By xc_ryd3r in forum Bike and Frame discussion
    Last Post: 05-17-2012, 10:22 AM
  4. rockshox recon silver tk silver question
    By bigturd in forum Shocks and Suspension
    Last Post: 03-24-2011, 07:36 PM
  5. Rockshox Recon silver R or silver TK?
    By seano26 in forum All Mountain
    Last Post: 03-01-2011, 10:16 PM
