    Mar 2013
    RockShox Reba Setup
    i just got my first air shox RockShox Reba RLT 26" 100mm
    i weight about 205lbs how much air do i need to put in it ???
    It depends on personal preferences. I`m ca 180 lbs, I ride 110+, 115-
    The rule-of-thumb is that it should bottom out once or twice on your ride. If the O-ring goes say only three-quarters of the way you are not taking advantage of all of your travel.
    Be aware that the bottomed-out position of the fork may not slide the O-ring all the way to the top of the stanchion. On my Fox there is about a quarter inch gap. You can let most of the air out to determine the max compression position, or if you ride it and if the O-Ring gets close to the top, assume it bottomed out.
    Mar 2013
    RE: RockShox Reba Setup
    Ok thanks
    Sent from my RM-845_nam_vzw_100 using Board Express
  1. RockShox Reba RLT 29
    By yabodie in forum Shocks and Suspension
    Last Post: 05-14-2014, 06:35 PM
  2. RockShox Reba RL vs. RockShox Recon Silver TK
    By jkrispies in forum Shocks and Suspension
    Last Post: 10-05-2012, 06:57 PM
  3. rockshox reba rlt 29 100 will it fit
    By Tx26257 in forum Shocks and Suspension
    Last Post: 05-20-2012, 09:18 AM
  4. RockShox Reba 29 RL VS Fox 32 F29 RL-100
    By Sharky1528 in forum 29er Bikes
    Last Post: 11-29-2011, 04:12 PM
  5. Rockshox Reba or Fox 32 F29
    By mtnfiend in forum 29er Bikes
    Last Post: 04-27-2011, 05:00 PM
