Results 1 to 5 of 5
    Reputation: thatdrewguy's Avatar
    road tube for tubeless 29?
    Can I use 700x25 tubes for emergencies if sealant fails to stop a leak? Tubeless tire size is 29 x 2.0.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    That would be stretching it pretty thin for reliable use. IMHO. A 700x38 might be more appropriate for reliability.
    Former Bike Wrench
    Well the tube will stretch but be extremely thin...your better off using a 26" tube which works fine in 29" wheels
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by thatdrewguy View Post
    Inflate one outside of the tire and see how it expands.
    Tubes increase in circumference much more than in cross section. A 25mm tube is not going to get big enough--especially at the valve--to work well in a 2" tire. I do not even like using a 700x40 tube. Ultralight 26x2.00 tubes work great, though.
    mtbtires.com
    Sounds like I better carry a "mtn tube" rather than one from the road, thanks.
  1. Replies: 47
    Last Post: 01-28-2010, 02:46 AM
  2. Tubeless or Tube
    By MI-29er in forum 29er Bikes
    Last Post: 06-09-2009, 03:50 PM
  3. Tube vs. Tubeless, which is better and why?
    By dirtluvraz in forum Wheels and Tires
    Last Post: 02-21-2006, 03:22 PM
  4. tube or tubeless
    By hmgreenfield in forum Wheels and Tires
    Last Post: 05-28-2004, 09:12 AM
  5. tube to tubeless
    By robotfood in forum Weight Weenies
    Last Post: 03-24-2004, 01:12 PM
