Results 1 to 2 of 2
    reviews on this bike please
    iron horse maverick 3.0
    specs:
    Frame: Aluminum with shaped down tube
    Fork: SunTour XCM (100mm travel/w adjustable rebound)
    Rear Shock: N/A
    Front Derailleur: Shimano SIS
    Rear Derailleur: Shimano Actus
    Shifters: Shimano Integrated 7 Speed Triggers
    Brakes Levers: Shimano Levers
    Brakes: Promax 160mm Disc Brakes
    Chain: KHZ Z Chain
    Crankset: SR Suntour
    Cassette: 7 Speed (21 Total Gears)
    Pedals:
    Bottom Bracket: SR Suntour Sealed Bearing
    Headset: Zero Stack Ahead Set
    Saddle: WTB Speed V
    Seat Post: Iron Horse RS Viper Series
    Handlebar: Iron Horse RS Eagle
    Grips: Porcupine Dual Compound
    Stem: Iron Horse Alloy 10 Degree rise
    Tires: ITS Ninja
    Wheelset: 6 Bolt Disc
    Weight: 30 lbs (19" w/pedals)
    Color: BLACK
    spec4life???..smh...
    Reputation: spec4life's Avatar
    There is one reveiw under the reveiw section.
    http://www.mtbr.com/cat/bikes/xc-har...8_1527crx.aspx
    Looking over the spec sheet, this looks to be a little below average for entry level bikes. Those brakes will need upgrading, they are just on there for looks. The deraillers are bottom of the barrel and it is only a 7 speed.
    Basicly it has a decent frame and fork that has lead to the comprimise of everything else.
