Results 1 to 6 of 6
    Resurrection project to help a patient - Knowledge appreciated!
    Resurrection project to help a patient - Knowledge appreciated!-20131005_181954.jpg
    Resurrection project to help a patient - Knowledge appreciated!-20131005_181922.jpg
    Resurrection project to help a patient - Knowledge appreciated!-20131005_181933.jpg
    Resurrection project to help a patient - Knowledge appreciated!-20131005_181948.jpg
    Resurrection project to help a patient - Knowledge appreciated!-20131005_181939.jpg
    Our budget is limited... 8 years in damp basement donation.
    Any donor part better than shown really appreciated + mention.
    What are these brakes called so I can narrow searches?
    Headrace?? Bearings... same thing.
    We need to have one front ring allowing only one gear change on bars.. cheap thumb/forefinger gear changers advice?
    A local body shop has pledged to spray and lacquer the frame.
    We would like to replace the rusty/worn bits any suggestions?
    Thanks in advance for any advice, Jem.
    PS Keep somone mobile
    Thats a older bike ,the 1" steerer tells me that ,looks like pastic pedals . The brakes are a tpye of V's . I would be real careful of speanding $ on that bike ,you could end up spending more than you would if you bought something else. Ebay for parts.
    Reputation: Pollution Warrior's Avatar
    I second the above post. Bikes like that can become a money pit real quick. Might be cheaper to get a used bike from a thrift store.
    Another option might be to take it to a bike shop, explain your situation, and see if they have any old take-off parts that they could just give you as a form of charity. Free labor might be another thing though so I'd plan on repairing it myself.
    Thanks for the replies.. may look at other options
    Moderator Moderator
    That bike looks like with some fresh cables and a few hours of elbow grease it could likely be rideable. Are you sure you actually need any new parts? Some lube and adjustments can go a long way.
    FWIW, I wouldn't waste my time getting it painted. Way more hassle to strip it and rebuild it than it's worth.
    AZ is offline
    Reputation: AZ's Avatar
    Cables, brake pads and a new chain. Throw in some grease for bearings. Probably source some take off pedals at the LBS.
  1. Resurrection 2004 5Spot Maybe.....
    By Gunslinger in forum Turner
    Last Post: 07-15-2012, 02:44 PM
  2. Resurrection Yet?
    By Wild Nature in forum Alaska
    Last Post: 07-11-2012, 05:21 PM
  3. 1993 Hilltopper resurrection
    By gearhead313 in forum Mongoose-Schwinn
    Last Post: 05-16-2012, 12:51 PM
  4. Wildfire Resurrection Project
    By kingpin_75s in forum Fat bikes
    Last Post: 10-10-2011, 07:42 PM
  5. Resurrection ride video
    By mtnsld in forum Alaska
    Last Post: 07-16-2011, 11:56 PM
