    Reputation: ncblue's Avatar
    Replacing freewheel - new chain also?
    Is it okay to replace the freewheel without replacing the chain?
    I put a new freewheel on and I swear Im hearing/feeling some grinding. I only swapped the freewheel because I had it off servicing the axle bearings. I thought I might as well put the new one on I had bought for a spare.
    I used the old chain, which has probably less then 6 months worth of riding on it. I removed it and gave it a good cleaning and lubricating.
    Yes, it's an old 7 speed freewheel.
    Chris
    2005 Walmart Schwinn (slightly modified)
    Still going...
    Reputation: Kaba Klaus's Avatar
    The freewheel goes over the axle, the cassette goes over the freewheel, the chain goes over the cassette... So, freewheel and chain are separated by the cassette (which has the 7 cogs).
    There is absolutely no need to replace the chain when you replace the freewheel. You don't have to replace the cassette either.
    You should check the chain when you replace the cassette, though. When the chain is worn you can indeed experience grinding. The old chain will wear the new cassette down rapidly. The age of the chain doesn't really matter. A chain wears out by stretching. The more you hammerfest (large gears, huge effort) the faster the chain wears.
    A bike shop has a ruler that tells you in 10 secs if your chain is worn. Otherwise you can measure yourself: http://www.sheldonbrown.com/chains.html (also a very good article on chains and sprockets/cassettes).
    "Lorem ipsum dolor sit amet, consectetuer adipiscing elit." - And I agree.
    Kaba, I think you are confusing a FreeHUB and a FreeWHEEL.
    NcBlue, If it's not skipping on you the chain should still be ok. Put it in the smallest cog and ride it hard and see if it skips. The grinding noise could be many things, check your derailleur alignment and make sure it's lined up properly. Hopefully you cleaned/lubed the chain properly.
    Quote Originally Posted by Mount Dora Cycles
    Duh - my bad. Good catch Mout Dora Cycles!
