Results 1 to 6 of 6
    Reputation: paqman's Avatar
    May 2005
    Replacement shifter
    Hey, I just purchased an old Specialized Rockhopper for my wife, see this thread.
    But the rear derailer does not work. I've found the problem, it's in the shifter. It's a Shimano Altus C10. One of the springs inside has lost it's coil, keeping it from grabbing onto the groove to pull the cable. I was just curious what my replacement options would be? I'm assuming they don't make this model anymore. If this were a car, I would head to the junkyard, and rip the part off another car, but I don't know of any bike junkyards!
    I need it up, you need it down. You don't see me complaining when you leave it down.
    Oct 2007
    Ebay is the equivalent of the junkyard for bikes. How many speeds is it. You don't neccesarily need an Altus shifter. You just need to find a Shimano shifter for the same number of gears. I assume it is either 7 or 8, in which case you could look on ebay for an old Deore, LX or XT 7 or 8 speed shifter.
    Former Bike Wrench
    Might be able to resurect
    Quote Originally Posted by paqman
    The grease in the Shimano shifters hardens over time, overpowering the weak springs and not allowing the pawls to engage. I have resurrected literally dozens of old Shimano shifters by simply saturating the insides with WD40...REALLY
    After saturating it, start to work the shifter. Soon, those pawls will loosen up and the shifter will begin to work. Once you get the shifter working, dry out as much of the WD40 as you can, then lube the shifter with a light oil like tri-flow
    Give it a try before replacing
    May 2005
    Quote Originally Posted by mtnbiker72
    Wow, great idea. Thanks! The spring really looks like it's unwound itself, and the grease seems thick, but not hard. But I'll definietly give this a try.
    May 2005
    Quote Originally Posted by ljsmith
    Thanks. I think you're right, I think it's a 7 speed, but I"ll count.
    Jul 2015
    mtnbiker72,
    Despite being an ancient thread I registered with the forum to thank you for this.
    This result was my first search result and it has worked perfectly.
    Being rather a novice my attempt was to renovate a nineteen year old budget MTB for my thirteen year old to use for school.
    My first thought was the local bike shop but all fixed now so again; thanks and best wishes.
