Results 1 to 3 of 3
    removing SR Suntour XCR crank arms
    I have a SR Suntour XCR crankset that I'm attempting to remove so I can check out the bottom bracket. Before getting to use a crank puller on the crank arms, there's a cap covering the slot that needs to be removed with a hex wrench. I've been able to remove the cap where the drivetrain is since the LBS might have removed it recently to do some work on the chainrings, however the cap on the other side I'm not able to even budge. I'm assuming because the drivetrain cap was removed via a counter-clockwise rotation of the hex wrench that the other side would be a clockwise rotation? Any tips on how to remove this cap?
    Reputation: etboost's Avatar
    If that's a square taper, then.hex bolts u r talking about r regular thread, just use some muscule counterclock wise...
    ugh, I soaked that hole with WD40 overnight and then wiped up the excess this morning... unfortunately when I tried going counter-clockwise on that damned hex I was beginning to strip it with the amount of force I was using. I think I'm gonna have to take this into the LBS to have them have a crack at it unless there's any other suggestions?
  1. need help with stylo gxp crank, gap between cups and crank arms?
    By Rasterman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-28-2014, 04:46 AM
  2. Help removing PF30 crank arms
    By TiGeo in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-23-2012, 07:38 PM
  3. Replies: 1
    Last Post: 03-11-2012, 06:18 AM
  4. crank/bb removal trek 3700 - sr suntour crank
    By Jason B in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-27-2012, 12:03 PM
  5. XTR Crank Arms
    By JasonByers in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-08-2011, 05:43 PM
