Results 1 to 10 of 10
    Removing a chain from mountain bike
    I purchased a chain removal tool from Walmart and tried to remove my chain with it. The chain rivet remained in place and busted the chain removal tool! Is there a trick to this or did I do something wrong?
    Dirt Abuser
    Reputation: Bail_Monkey's Avatar
    What type of chain is it? KMC, Sram, Shimano..... does it have a masterlink?
    "Don't ride faster than your guardian angel can fly"
    I have no idea. I didn't see a master link. I want to pull it off an oId Trek 820 (2005 model). If there is an easy way to do it by cutting it, that's fine too because I do have a new chain to replace it, and a friend of mine has a tool to help me put the new one on.
    Quote Originally Posted by getagrip View Post
    ... a friend of mine has a tool to help me put the new one on.
    Same tool.
    EDR
    Reputation: eatdrinkride's Avatar
    Jun 2005
    I have an '05 820 in my garage. It's got a Shimano chain I think. Anyhow sounds like you're going about it right, you just bought a super POS Chinese tool.
    Anyhow you need to pop one pin out of a link and the chain will come off (using a chain tool). Measure the new chain to the same length as the one you removed and drive in a new pin. You'll snap the guide pin portion off once done. If none of this makes any sense I suggest googling "Sheldon Brown chain replacement."
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I have to admit, I laughed out loud. Walmart quality, FTW!
    Is it possible that you didn't have the pin in the tool quite lined up with the pin in the chain? In theory everything should line up automagically, but that doesn't always happen.
    Since the tool is broken now, maybe just ask your friend for some help.
    well if theres no masterlink, your chain tool is broke and you have a replacement chain anyways..... go the fun route and break out the bolt cutters or a few flathead screwdrivers jammed in the links and snap that rusty thing off....
    Wow. This is embarrasing. I've got everything off the bike except the headset, bottom bracket, and everything attached to the chain! Guess I'm going to have to go back to Walmart and see what tools they have to finish the job!
    I think maybe going back to Walmart might not be the best plan
    Turns out it was the right plan. I had gone there earlier to get a refund for the other chain removal tool I purchased, and from there proceeded to several other stores that might also carry a chain removal tool, but neither store stocked one. After realizing I didn't have the proper tools at home to get the job done, I decided to go BACK to Walmart to add to my tool collection, which is pretty small. Instead of buying new tools, I pretty much said the heck with it and took my chances on another chain removal tool. Turns out that I may have been using it wrong by not placing the chain up against the thicker metal wall of the tool (not that this was explained very well in the instructions - basically, there are two notches that the chain will go into, one is supported by a thicker metal wall on the edge of the tool, and the other is supported by another notch). This time I was able to get the chain off no problem.
  1. Compagnolo chain on mountain bike?
    By mikejones222 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-15-2009, 07:05 PM
  2. Removing a chain with chain tool
    By djork in forum Tooltime
    Last Post: 09-08-2009, 09:16 PM
  3. Removing Chain
    By spec4life in forum Beginner's Corner
    Last Post: 07-01-2008, 12:13 AM
  4. removing a chain..
    By jimi1114 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-04-2007, 06:46 PM
  5. Does anyone use a chain guide on their All Mountain bike?
    By bullit71 in forum Downhill - Freeride
    Last Post: 01-03-2006, 08:38 PM
