Results 1 to 15 of 15
    Reputation: Gabe3's Avatar
    remove plastic chainring guard?
    my bike came with a plastic chainring guard, should I keep it on there till it breaks off probably, or remove it now?
    Reputation: sturge's Avatar
    If you're talking about the plastic ring behind the cassette on the rear wheel, yes...try to get it off. It will eventually break and cause issues at precisely the wrong time.
    07 Kona Dawg Supreme
    12 Santa Cruz Heckler
    18 Kona Process 153 AL/DL (27.5)...
    If you are talking about the plastic ring on the outside of the big front chainring, its not a chain guide, its there to stop long pants from hooking up on the sprocket teeth and can be got rid of no problem or it will break the first time it hits a log across a track
    Quote Originally Posted by sturge
    already removed that, what a pain in the ass it was.
    i'm talking about this:
    Quote Originally Posted by jeffgre_6163
    I mean guard, not guide, sorry.
    meow meow
    Reputation: b-kul's Avatar
    i would but you dont have to.
    Oct 2010
    i "removed" the plastic one on my bike with a rock on the trails a few days ago. lol.
    Reputation: William_Cannon's Avatar
    What damage do "dork disks" cause? I still have mine on, but it's starting to get loose.
    Dork disc's make your bike look cheap, they aren't cool and they really serve no purpose.
    Trail Ninja
    Reputation: Varaxis's Avatar
    I'd keep it until it breaks. It'll serve as a reminder to do better on that part of the trail that broke it.
    We're all on the same ship, and it's sinking.
    Quote Originally Posted by William_Cannon
    it can break off and get stuck in the spokes, moving wheel+something in spokes=bad outcome.
    Quote Originally Posted by burger49
    so if your chain goes over low gear and towards your wheel, the dork disc doesn't protect the spokes at all?
    Feb 2010
    The one on the rear cassette is just bad compensation for a poorly adjusted drivetrain. If everything is set up properly, it isn't needed.
    Quote Originally Posted by jtemple
    Agreed, but all it takes is a fall to get your derailleur out of whack on the trail.
    Please remove it. It will be one less piece of trash someone has to pick up.
