Results 1 to 3 of 3
    AKJ
    AKJ is offline
    Dec 2013
    Remove 15mm to 9mm QR adapters from hubs
    I'm trying to remove 15mm to 9mm QR adapters so that I may use a 15mm solid axle fork. I didn't put the adapters in, but from the images here it looks as though they just pop in.
    I read another post where a guy claimed he used a skewer and a mallet, but I can't think of how that would actually work since the skewer goes through without hitting anything.
    From the illustrations the center of the hub is open. You should be able to put the skewer in on an angle so it hits the far cap without going through the hole. Then just tap it to remove the cap.
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    The caps stay on by a single 0-ring. Slight, angled tap with a mallet and it easily pops off.,
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
  1. 15mm to 9mm dropout adapters?
    By Flat Ark in forum 29er Components
    Last Post: 09-15-2013, 03:48 PM
  2. CB Iodine 15mm hub adapters
    By bayareaflip in forum Ibis
    Last Post: 08-02-2013, 08:13 PM
  3. 15mm QR to 9mm QR fork adapters.........
    By qkenuf4u in forum Shocks and Suspension
    Last Post: 06-17-2013, 03:50 AM
  4. 15mm Through Axle adapters?
    By BigDaddyFlyer in forum Airborne
    Last Post: 03-24-2013, 05:45 PM
  5. Replies: 7
    Last Post: 09-19-2012, 04:59 PM
