Results 1 to 11 of 11
    Jan 2014
    Recommendation for a New Fork! A beginner needs your help!
    asg
    B A N N E D
    (27.5 right?)
    No, 27.5" is a wheel size, 26" and 29" are also wheel sizes.
    The Specifications say ..... Tires: Schwalbe Rapid Rob, 26x2.1
    This means that your bike has 26" wheels and you'll need a fork for 26" wheels.
    Forks have either straight 1 1/8" steering tubes or tapered 1.5" to 1 1/8" steering tubes.
    The Specifications also say ..... Headset: Tange Reducer 1.5 - 1-1/8"
    I'd say this means your frame has a tapered head tube with a reducer headset to fit a fork with a straight 1 1/8" steering tube.
    If it does you could put on a fork with a 1.5" to 1 1/8" tapered steering tube if you change the headset setup.
    You can use a fork with a straight 1 1/8" steering tube without changing anything.
    In your price range the following forks might also be worth looking at:
    Manitou R7 Pro is about 1.5kg
    Manitou Marvel Pro is about 1.5kg
    Manitou Minute Pro is about 1.6kg
    CRC has some good prices on forks: http://www.chainreactioncycles.com/u...spension-forks
    Jan 2014
    kgu
    B A N N E D
    Quote Originally Posted by sarputso View Post
    So these you mentioned are actually better than the ones that i've listed?
    I'd say they're of similar quality to the Reba's, I don't know how they'd compare to Magura forks.
    The R7's have 30mm stanchions which makes them slightly more flexible then the Marvel's and Minute's which have 32mm stanchions like the Reba's.
    I ride bikes
    Reputation: moefosho's Avatar
    Apr 2013
    There are a few things that you need to consider when purchasing a new fork.
    1. Steer tube length. Is it long enough? If its too short, it wont work.
    2. Steer tube Diameter. 1 1/8", Tapered, or 1.5" ?
    3. Axle size. 9mm QR, 15mm, or 20mm? You need the correct axle size on the fork to fit your wheelsets hubs. Otherwise you need new hubs or wheels.
    4. Travel/ Axle to crown height. Axle to crown is the most important as it determines the effect on geometry that the new fork will have. Travel is important because it effects A-C height. Normally you dont want to go more than 20mm of travel than what your frame was designed for. For instance, your bike has 100mm of travel. So try to find something in the 100-120 range.
    Jan 2014
    outdtyd
    Jan 2014
    Thank you very much. I will consider your suggestion.
    TRAIL SL 4 - Trail SL - Hardtail - Mountain - Bikes - 2013
    Jan 2014
    Any recommandation for a quality multi tool set? Crank brothers?
    Reputation: watts888's Avatar
    Oct 2012
    Can't go wrong with the crankbrother's or park multitools. I've used the crankbrother's knock-off from Nashbar and so far it's worked ok. The problem with the larger "21-function" multitools, it normally means you just have an extra cumbersome tool to hold onto while trying to tighten a bolt in a tight place. It's good to have if you're far off the grid and have to be completely self reliant for repairs. If you're within walking distance to anything resembling civilization, I'd limit my multi-tool to the basic hex keys, torx key and philips screwdriver, especially if you're riding with someone that has the "21-function" multi-tool.
    Park Tool Co. AWS-9 : Fold Up Hex Wrench Set : Hex Wrenches
    Park Tool IB-2 I-Beam Mini Fold Up Tool | Park Tool | Brand | www.PricePoint.com
    Jan 2014
    ,bvjv
    R.I.P. DogFriend
    Reputation: jeffj's Avatar
    I've decided on this tool:
    ++ multi19 :: crankbrothers.com ++
    I have that exact multi-tool. It's a quality multi-tool. The metal canister is OK for putting into a Camelbak, but a little bulky for sliding into a pocket, so sometimes I just leave the canister at home.
    When you have used up the Zefal patch kit, if you're looking to try something else, the Park Tool super-patches are good for a quick, down and dirty trailside patch, and the Lezyne patch kit is also recommended the same situations:
    Lezyne Patch Kits
    For regular tire patching duty in the garage at home, the good ol' glue and patch method works well.
  1. Fork Recommendation, please
    By Maxx in forum 29er Components
    Last Post: 05-07-2012, 04:18 AM
  2. Need a fork recommendation - can anyone help?
    By KVW in forum Shocks and Suspension
    Last Post: 02-07-2012, 08:24 PM
  3. Beginner needs a trail recommendation
    By Over The Bars in forum Oregon
    Last Post: 09-13-2011, 08:33 PM
  4. Fork Recommendation
    By polecats03 in forum Shocks and Suspension
    Last Post: 08-08-2011, 02:37 PM
  5. Fork Recommendation?
    By OneEyeMan in forum Shocks and Suspension
    Last Post: 05-12-2011, 12:46 PM
