Results 1 to 10 of 10
    Mar 2013
    Rear wheel spoke guard - need it?
    I changed my wheels the other day and didn't put that plastic thing back on the wheel after changing the cassette to the new wheel.
    Is that thing called a spoke guard? Do I need one?
    Perpetual n00b
    Reputation: dgw2jr's Avatar
    If you drop the chain between the cassette and spokes, you will gouge the spokes and they will be prone to breakage. I had that happen and had to have 3 spokes replaced. They always break at the worst possible moment.
    The leg bone's connected to the Cash Bone!
    Total Goober
    Most peeps remove them. Just check and adjust the limiter screw occasionally, and you should be good. As stated above, it's costly if the chain falls between the cassette and spokes.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    Just Ride
    Reputation: Cormac's Avatar
    Quote Originally Posted by speedneeder View Post
    I believe the proper term is "dork disc"
    SS ==> Nut up or Shut up!
    Jun 2012
    I've kept mine.
    2009 Stumpjumper Comp HT.
    An old Trek 820 ST.
    Mar 2013
    Thanks for the replies - I have had my chain between the cassette and the spokes a few times before upgrading wheels. Maybe I will put the dork disc back on!
    OTB Pro
    Reputation: meyer378's Avatar
    Learn how to set your limit screws and toss that dork disc. With your limit screws set correctly your chain should never fall between the cassette and the spokes.
    Mar 2013
    I will look into it - was thinking the learning phase might be better off with the dork disk
    Jul 2013
    Lose the dork disc! Bikes look so much better without!
    Reputation: Shakester's Avatar
    Jun 2012
    I debated if I should leave it off or on after changing cassettes, but it looks so much better without it. If you set your limit screws correctly, you're chain shouldn't drop unless you crash and bend your derailleur
  1. Ever used a 48-spoke rim for your rear Wheel ?
    By ThundaCrymz in forum Clydesdales/Tall Riders
    Last Post: 11-10-2012, 09:09 AM
  2. rear wheel build, spoke question
    By cunningstunts in forum 29er Components
    Last Post: 04-05-2012, 05:42 PM
  3. Bicycle Wheel Spoke Patterns and Spoke Fatigue
    By TigWorld in forum Wheels and Tires
    Last Post: 11-05-2011, 07:33 AM
  4. rear 24 spoke disc wheel?
    By urmb in forum Wheels and Tires
    Last Post: 03-22-2011, 11:46 AM
  5. wheel spoke help please
    By rs slim in forum Beginner's Corner
    Last Post: 03-13-2011, 03:56 AM
