Results 1 to 6 of 6
    Nov 2013
    Rear wheel/ Drivetrain issue
    Hello everyone, I recently purchased my first mountain bike about a month ago, a 2007 specialized stumpjumper carbon fsr from a friend. The bike has been awesome so far and I have put around 200 miles on it since buying it. The only issue I have had is when I am on a downhill section and have the bike shifted on to the largest (tallest) chainring the rear brakes seem to engage when the suspension is compressed, it makes a low pitched squealing noise, almost as if I were holding the rear brake lever. Sometimes I can get it to stop if I compress the suspension more as I am riding and sometimes it will only stop squealing if I pedal. I like to think I am pretty mechanically inclined and am wondering if it is a quick fix or if I need to take it in to get looked at. The bike has shimano xt crank/chainrings, SRAM front and rear derailers and magura hydraulic brakes. Thank you for any tips.
    I'd guess your chain is too short.
    Apr 2013
    That makes sense.
    Reputation: lotusdriver's Avatar
    Sep 2013
    Remove the shock, turn the bike upside down, and compress the rear suspension fully.
    You can then shift into the higher gesrs and see if the chain is becoming stretched to the limit.
    Nov 2013
    thanks for the info guys, I will try this tonight.
    Reputation: watts888's Avatar
    Oct 2012
    Quote Originally Posted by lotusdriver View Post
    doing this may allow the suspension system to compress more than the shock will allow. When you do this, measure the eye-to-eye length of the frame's shock connectors to the (shock length) - (shock travel).
    Might ask your friend if he ever had to remove some links due to a busted chain. A new chain is only $15-$30, so it's not a bad idea to get a new one anyway.
    troubleshooting if the chain isn't the guilty party. Check your brake cables and make sure they don't get kinked when you're compressing the suspension. Bend in the cable may push the rotors in just enough to squeel. downhill section could also be heating up the brakes, which transfers a litle heat to the calipers, which expand the oil, and causes the pads to move in and rub a litle bit.
  1. Mojo SL rear wheel issue
    By Smilerz in forum Ibis
    Last Post: 03-21-2013, 07:03 PM
  2. Help Diagnosing Drivetrain Issue
    By SJKevin in forum Beginner's Corner
    Last Post: 07-16-2012, 10:23 AM
  3. 135mm rear wheel axle issue
    By saxen in forum Ibis
    Last Post: 09-22-2011, 09:02 PM
  4. Drivetrain Issue
    By nov0798 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-06-2011, 04:26 AM
  5. Drivetrain issue - please help
    By yohyat in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-03-2011, 11:10 PM
