Results 1 to 3 of 3
    Rear Shock Question
    I feel dumb for asking, but how do you fill the rear shock with air? I noticed I cannot do it with my air compressor, and the hand pump I have doesnt create enough pressure. I'm sure there is a shock pump or something, but can someone point me in the right direction? It's killing me to not be able to ride because the shock has about 40psi in it, and for a 210lb rider, that just doesnt work. Not sure if it matters, but its a Fox Float R
    Are you talking to me?
    Reputation: damion's Avatar
    Jun 2003
    You are right.
    You need a shock pump, rated for high pressures. You can get one at your Local Bike Shop, or order one.
    gfy
    easy enough, thanks for the response. To the bike store I go!
