    culturalpreserve
    Rear Hub / Axle advice please???
    Hi can anyone help.
    I have a Be One Woodbumble plus and i'm researching a new rear wheel set up.
    But i'm confused. The gap between rear drop offs (if you can call them that as its a bolt) is 183mm. But most hubs i've seen such as Hope Pro II have measurement 135mm or 150mm.
    Are the two related or am i looking at the wrong measurement?
    Apologies for the poor explanation. I'm sure through replies etc the real problem will come out.
    Cheers
    meow meow
    Reputation: b-kul's Avatar
    looks like a dh bike. probaby a 150mm but im not sure. 150 is the hub length, not the axle length.
    culturalpreserve
    Found more info
    Thanks for your help. I did a bit more digging.
    When i tightened the rear bolt to its normal tension i found that its a 165mm hub that's needed. I've had a look around and Sun-Ringle and Hadley are the only makers of a 165mm hub. I called Hope and they've never made one.
    If anyone knows of any manufacturers who do a 165mm hub with 12mm bolt please let me know. Also if anyone has one for sale i'll be keen to discuss.
    cheers
    Old man on a bike
    Don't pay much attention to dh stuff, but poked around a bit and see this http://www.bikeparts.com/search_resu...p?id=BPC101534
    Much better posted in the dh forum, tho...
    suum quique
