Results 1 to 3 of 3
    Reputation: akacoke's Avatar
    really need your help with my marzocchi dirt jam pro fork
    Hi, i just bought a kona scrap came witht the 100mm dirt jam fork
    one leg have air oil and the air side leg should have a internal rebound adjuster to be adjusted with a " 12mm tee-key" its covered with oil, the color of the oil is kind grey/black yellowish. is that color normal? also the air side leg is almost covered by oil . the other side is dry.
    the other side have spring and no oil inside there is also a lot of grease on the spring, also the top cap is a preload adjuster with no o-ring or seal to keep the dust out, do all this sound normal to you?
    the fork pushes down and comes back real real slow, i can here the oil moving and compressing while is bouncing back
    also, i tried to pump the air to spec from the user manual, i couldnt cuz my tire pump have a adapter thats too big to fit the nut of air valve on the cap of fork. is there a slimmer adapter i can buy that attaches to my pump and smaller enought to fit?
    im a total noob about this fork stuff. please give me some hints of what i should do to make it normal.
    thanks in advance .
    Attached Thumbnails Attached Thumbnails really need your help with my marzocchi dirt jam pro fork-pc140353.jpg
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    You'll need a shock pump to add the air, they're designed to pump to the low volume and high pressures of a fork or rear shock.
    As for the slow rebound, did you adjust it with the 12mm hex as described in the instructions?
    The oil looks dirty, not a huge problem, but if you change it you'll need the proper viscosity fork oil and you'll need to know how much to put in. Try to find service instructions for the fork online.
    The spring grease is normal. Let us know how it goes.
    "...like sex with the trail." - Boe
    I'd be lost
  1. Marzocchi Dirt Jumper for Dirt
    By Nicker in forum Beginner's Corner
    Last Post: 05-07-2010, 01:05 PM
  2. Replies: 1
    Last Post: 04-30-2009, 05:00 PM
  3. Surly Instigator with a 2004 marzocchi dirt jumper 2 fork
    By alfiegee in forum Downhill - Freeride
    Last Post: 04-28-2009, 12:55 PM
  4. New Fork Please Read (2006 Marzocchi Dirt Jam Pro - mod title edit)
    By bikeperson in forum Shocks and Suspension
    Last Post: 11-15-2007, 01:04 AM
  5. headlock solution for marzocchi fork-dirt jump I
    By nrdbomber in forum Urban/DJ/Park
    Last Post: 10-14-2006, 08:21 PM
