Results 1 to 3 of 3
    Quick Tips Before First Brake Installation?
    Hello all,
    I just got a set of SRAM 9.0 V-Brakes ( levers, brakes, wires, etc.. ) and after looking over the directions, they don't seem very detailed... This will be my first ever installation, but I figure it shouldn't be hard to install and would be a good learning experience.
    Any general quick tips before I start installing them later today? Any websites out there with tips too on bike upgrades/etc?
    Thanks a lot,
    Daniel
    parktools.com
    sheldonbrown.com
    utahmountainbiking.com
    I'm sure there are others too. Do a google search and you will find them.
    Good luck, allow extra time and no interruptions and you'll be fine. If you have an "assembled" bike to use as a model, keep it close by.
    Cheezy Rider
    Reputation: Rufudufus's Avatar
    Make sure to grease your stanchions (the cyclinders sticking out of the frame that the levers slide on to) before you assemble. I forgot to do this and my brakes were a bit sticky. Work on one brake set at a time so you don't have bunch of parts laying around.
    If you don't have a cable housing cutter, a Dremel tool with cutting wheel works pretty good. You'll need a thick pin or small nail to ream the hole in the end after cutting.
    Like bmateo says, take your time and eliminate distractions and you'll be fine. If you try to rush this job it's a chore. If you take the time to see how things go together and get them dialed in it's kind of fun.
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. Adaptor for disc brake mouting on forks?
    By dawgcatching in forum Brake Time
    Last Post: 12-25-2004, 12:17 PM
  3. Any Hope Mono Mini set up tips?
    By Burger in forum Brake Time
    Last Post: 07-19-2004, 11:01 AM
  4. Marzocchi and disk brake installation
    By dcbeards in forum Downhill - Freeride
    Last Post: 06-19-2004, 12:34 PM
  5. Rear V brake adjustment with ENO hub?
    By jh_on_the_cape in forum Singlespeed
    Last Post: 06-08-2004, 01:24 PM
