    Feb 2012
    Queston about front end.
    I have noticed recently that when I am going down a hill or mashing my pedals that I hear a rubing.
    It sounds like my tire hitting the crown (I think that's what it's called) of my fork. I am running a 2.4 tire in the front and have noticed that while there is clearance there isn't much.
    It's tough to tell where it's comming from since I can't duplicate it unless I am riding and I don't really want to look down at it for obvious reasons.
    Any suggestions appreciated.
    My little friends
    Reputation: EABiker's Avatar
    Assuming that you have an air fork.....are you running enough pressure?
    Feb 2012
    Not an air fork. The fork is a POS but it's been fine untill recently.
    Reputation: J.B. Weld's Avatar
    If the clearance is real tight it probably is the tire, put a smaller one on and check it out.
  1. 3x9 front derailleur on a 3x8 setup (to solve rockhopper 29 front shift issues)
    By samandkimberly in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2013, 04:37 AM
  2. Giant STP rear wheel/hub queston
    By JayMac in forum Wheels and Tires
    Last Post: 03-03-2013, 05:38 PM
  3. Replies: 4
    Last Post: 09-13-2012, 01:33 AM
  4. What bike should I get queston (million and 1st time)
    By bandit1 in forum Beginner's Corner
    Last Post: 07-21-2012, 12:16 PM
  5. will 2x10 shimano m980 xtr front shifter work with sram xx front derailleur?
    By gideon in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-01-2012, 06:28 AM
