Results 1 to 8 of 8
    Feb 2013
    Question on replacing front shift lever?
    So I went over the handlebars yesterday and broke my front (left) shift lever. Can I replace my XT M760 9 speed with a XT M780 10 speed? Probably a silly noob question, a triple is a triple, but just want to make sure before I purchase.
    Reputation: Shakester's Avatar
    Jun 2012
    Yes, you could. It should work just fine.
    May 2013
    No, you can not use a 10 speed shifter with a 9 speed set up. The indexing (amount of distance the cable-and in turn the derailleur is moved per shift- is different for 9 speed vs 10 speed shifters. You will need to buy a 9 speed specific shifter.
    Ride-aid is right ,different cable pulls. E-bay has a ton of shifters.
    Jun 2012
    Quote Originally Posted by Ride-Aid View Post
    The left shifter usually refers to the front derailleur so he could use nearly any kind of shifter that is a 3x since the pull ratios are the same. If he were talking about the rear, then no.
    Total Goober
    Quote Originally Posted by Jeremy1983 View Post
    ...a triple is a triple...
    Looks like that shifter can be set up for 2X and 3x, in case you change in the future.
    Quote Originally Posted by Fuglio View Post
    You guys suck im all bummed now
    Feb 2013
    I found and bought the XT SL-M770 9 speed. Thanks for the replies.
    Reputation: CRchris1996's Avatar
    you can I actually did because I needed shifters and want to go from 9 to 10 but dont have the money by the moment the only con is that chain will grind a little bit on the smaller gear of the pinion
  1. elixer brake lever position, vs shift lever
    By thecanoe in forum Brake Time
    Last Post: 10-25-2012, 04:04 PM
  2. shift lever/brake lever position
    By thecanoe in forum General Discussion
    Last Post: 02-11-2012, 06:52 PM
  3. which shift lever?
    By madduck in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-23-2011, 12:55 PM
  4. Deore 3sp front shift lever to 2sp?
    By curtboroff in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-21-2011, 05:23 PM
  5. Can't...reach...shift...lever
    By beanbag in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2011, 11:58 PM
