Results 1 to 5 of 5
    Jul 2013
    Question about tire width
    The bike I have came with 29x2.20 tires. I was wondering if 29x2.35 or other widths would work?
    I have the Trek Mamba and the wheels are;Formula DC20 LW alloy front hub; Formula DC22 LW alloy rear hub w/Bontrager AT-850 32-hole double-walled rims
    Usually the limiting factor is in the rear. How much clearance do you have between the chainstays and seatstays? Check your fork too, but forks are usually fine.
    Surly Cross Check: fat tire roadie
    Surly LHT: Kid hauler
    On One Inbred: SS 26er
    A 2.25 Nobby Nic Perf. or Racing Ralph Perf. would go on the rear and give you good traction, the RaRa would be faster. The Nobby Nic would add a little more cushion at the back. The Nobby Nic makes a great front tire for hardpack and loose over hard with less washout in curves for me than a Ra Ra. A wider tire would fit on the front.
    Reputation: jetboy23's Avatar
    Its not a matter of "will a 29x2.35 tire fit?", its a matter of "will a 29x2.35 Hans Dampf fit?". All tires are different and the measurements are not identical even though they may be marketed as such. I gave the HD as an example because it has been reported to be closer to a 2.5 than a 2.35. And Continental tires are generally smaller than the listed size.
    Quick answer, most likely. But, not 100%.
    Jun 2013
    Quote Originally Posted by jetboy23 View Post
    +1
    There isn't a hell of a lot of room between the chainstays on those frames, so 2.5 would be pushing it, 2.35 is going to be close, and 2.2 is a pretty much a sure things.
  1. Wheel width VS tire width
    By Fox Fire in forum Wheels and Tires
    Last Post: 12-30-2012, 01:03 PM
  2. Tire Width Question
    By Fatty In Hamilton in forum Fat bikes
    Last Post: 12-05-2012, 11:15 AM
  3. "newbie" tire question regarding width.
    By jjc155 in forum Wheels and Tires
    Last Post: 09-27-2011, 05:29 AM
  4. Tire width and rim width recomendations
    By mtbfan2 in forum Beginner's Corner
    Last Post: 08-01-2011, 03:52 PM
  5. rim width, tire width
    By kimbroughhg in forum General Discussion
    Last Post: 05-01-2011, 06:41 PM
