Results 1 to 7 of 7
    Question about adjusting tension on my M520 pedals
    Hi,
    I just received my M520's and have been playing with the tension adjuster. Some questions:
    1) should the tension adjuster be pretty stiff to turn? Seems harder to turn than I would have expected. I'm afraid I may have actually stripped one trying to turn it.
    2) do they stop turning once they've reached max/min? how do I know if they are both at the same level?
    3) what exact movement should I be able to see happening as I adjust tension? I'm trying to watch closely as I'm doing it but I don't really see any parts moving (ie: plate or spring) - are movements really subtle?
    4) the silver part that has the tension adjuster on it, should I be able to bend that back with my bare hands when set on easiest (since I'm pretty sure this is the part that moves forward during the clip in process? won't budge!
    5) lastly (and I hope this doesn't sound too dumb!), should I be able to "clip in" while holding the pedal in my hand and my shoe in the other hand - just wanted to see/feel how it all works before I installed them.
    Thanks for your help!
    1) If I remember correctly mine is stiff, but not overly so.
    2) Yes, I believe they do.
    3) I don't think you can really see any movement, I am trying to picture the pedals, you may be able to see some movement if you look in towards the middle of the pedal, but no large obvious movements.
    4) I can't really move mine with my hands, but that could be down to hand strength more than anything. If you can't move it with your hands, I would not worry about it.
    5) Yes, you can, and no, it does not sound too dumb. I did the same when I first got mine. It's handy to get a feel for the movement of the shoe when releasing it from the pedal.
    i bought mine used from somone
    i just use it on the road to get a feel of the "tightness"
    and try to yank it out using different strength
    if it pops up too easily, increase the tension 1 time as a time and try it over and over again till you feel is ok.
    ya might need to fine tune it once riding on trail again.
    Thanks a million! I was able to get them clipped in using my hands - not easy though! Now for the real thing.......nervous!
    Reputation: Trail_Blazer's Avatar
    May 2012
    I have had one out of three that was very stiff to turn the screw but it worked fine with some grunting.
    Start with the easiest level and work your way tighter as needed.
    Be sure to adjust the screws on both sides of each pedal.
    Find a nice soft patch of grass to practice getting out of them while pretending like you were falling over and try to catch yourself.
    If you wait until you are about to fall on the rocks to practice then you will surely bleed. lol
    ya can try this to see if it is too loose anot.
    when both feet are clip in, ride fast across a road hump, use the leg to compress the bike and jump up
    it should not unclip by itself, if yes, it is too loose for safety in trail.
    just tighten it till it wouldn;t unclip by itself.
    Reputation: JasonScottCarter's Avatar
    Mar 2006
    I just got 520's this week as well.
    Mine was stiff at first (I think they come with the tension set on the hardest) Don't think you will hurt the pedal, might break your allen wrench if it's cheap, but highly unlikely.
    Yes, they stop turning. How you know they are are the same level is to count how many turns you make on one, then repeat on the other adjustment knobs.
