Results 1 to 9 of 9
    Jan 2011
    query on suntour xcm v3 100mm hlo fork
    Hi,
    do we need to do any maintenance on suntour xcm v3 100 m hlo forks? My trek 4500d 2011 model came with them. response and travel doesnt seem much. I ride on roads and sometimes hit potholes. Is tuning required ? I see some travel , but not much.
    The Owners Manual is on Suntour's site. Not much you can do. Clean and grease bushings lubricate dust seals.
    Aye, most forks that you see on bikes sub $1k would be safe to ride into the ground, and replace with something else. Once a critical part breaks, replace it with a Marzocchi Marathon or a Rockshox Tora solo-air for budget sake, or go as nuts as you want.
    If I'm remembering the correct fork, it is difficult to remove the lowers (or more accurately, to put them back on) to access the seals for a real cleaning, so wipe it down after each ride, and make sure to use a fork oil/silicon lubricant on the stanchions near the seals, compress, and wipe down. That will keep everything working as smooth as can be expected.
    Oct 2011
    Nah, shouldn't be difficult to take the fork apart and re-grease it. What you need to do is take the lowers off, clean everything down there, clean the spring, put some sticky grease over everything and put everything back together again. The fork should work ok after that.
    Oct 2012
    its reall easy, flip the bike upside down, remove the two 10mm nuts and pull the lowers off. clean out all the sandy gritty grease, wipe down the inside of the fork seals and replace the grease with thin syntetic grease. you have to do it alot with the xcm.
    Jan 2011
    thanks all, how do I adjust the preload control knob? There is a S shaped plastic knob. I turned it with a wrench, but that seems to damage the knob.
    Oct 2011
    Quote Originally Posted by sanjayc View Post
    Hmm I'm positive you should be able to turn it with two fingers without any problems... There must be some defect or something, the preload knob is probably stuck.
    The plastic threads often get warped if someone gorillas the knob into one or the other extreme. It may be fine if you can unstick it, but it may also be permanent.
    Jan 2011
    The knob does not seem to be damaged that much. How do I get the knob (preload knob) unstuck?
