Results 1 to 8 of 8
    Addicted to the Ride
    Reputation: Fitness_Freak's Avatar
    Putting 29ers on my frame?
    I recently bought s Scott aspect 30. I was wondering if a set of 29ers could fit if I wanted to switch down the road? Thanks!
    You might be able to put a 29" on the front. Take a look at the 69er forum.
    No. The radius is about 1.5 inches more. In the rear, the chainstays you have are short for good handling and climbing. A big wheel would get pinched between the chainstays near the seat tube, or hit the seat tube. In the front, the big tire would hit the fork brace. People convert to 69ers by putting a new 29er fork on yur frame. You could do that, but be aware that your front end will be raised and your head angle would slacken, which will effect handling, especially steering precision.
    Like RedBen said, check out the 69er forum for people who have made that conversion. A lot of them switch to 29er rigid forks, which aren't as tall as suspension forks, to minimize the height and handling problem.
    If you just bought the bike, go enjoy it and don't worry about not having the latest fad.
    Two Wheel Offroad
    Reputation: T_W_O's Avatar
    Quote Originally Posted by smilinsteve View Post
    +1, it would just 'f the geometry, and would ended up costing you more for upgrades and fitting. Might as well save up and buy a 29er.
    Without knowing anything about the frame, what about 650b?
    If it's got a Fox fork you could go 650B, it's what I'm seriously considering for my bike
    OG Ripley v2
    Carver 420 TI
    Thanks for all the input! It has a suntour xcr for the front fork. Could a 650b work then?
    Two Wheel Offroad
    Quote Originally Posted by Fitness_Freak View Post
    Yes and no, it would fit but you may need to shim the fork internally. It's much better to get another bike.
  1. Putting frame back together problems
    By Shiba Inu's Rock in forum Diamondback
    Last Post: 05-17-2011, 03:36 PM
  2. HELP! putting back together an FSR XC Frame
    By lpranal in forum Specialized
    Last Post: 09-23-2008, 06:58 AM
  3. Putting a 100mm fork on a 80 mm frame?
    By rharriman in forum Shocks and Suspension
    Last Post: 06-30-2006, 01:44 PM
  4. Anyone ever try putting a rigid fork onto a rear suspension frame?
    By SpawningGround in forum General Discussion
    Last Post: 12-22-2005, 11:41 AM
