Results 1 to 5 of 5
Thread: pls delete
    Jun 2013
    pls delete
    Mods -- pls delete. Didn't notice the pinned topic that covers most of my initial questions.
    Im somewhat new - have been riding about 9 months.
    you need a chain tool to remove the chain. Cleaning and lubing the chain on the bike is my most common maintenance item. I also wipe down the shock and fork to remove dust dirt after every ride After that is cleaning the drivetrain, maybe once a month.
    Knowing your pump to get the right pressure every time is very useful
    The next most common thing is probably adjusting the drive train when shifting gets messed up. this seems to happen every 5th ride or so. Often times it is a bent derailleur hanger.
    As for periodic maintenance, changing wear items like tires and setting up tubeless tires is next most useful.
    changing brake pads is something that I had to do in the first month but now I am much easier on my brakes.
    Adjusting the location of brake levers/shifters is something I did early on but dont really have to do now.
    I check my wheels to make sure they are still tensioned properly. I had to replace a spoke on a used bike that I bought.
    I have greased the pivots of my FS bike once
    I have lubed my bottom bracket once
    I have lubed some old shifters once
    I check the nuts/bolts of everything every few months or whenever I think about it (stem, handle bar, brake rotors, chain ring bolts, seat pedals, quick releases etc) . They sometimes get loose. My friend rode my bike and he said the front felt loose. Turns out my headset had loosened up.
    What could go wrong ...
    Reputation: Zoke2's Avatar
    Nov 2007
    There is a sticky at the top of the Beginner's Corner that covers all of this
    Basic Cleaning and Maintenance Guide
    I used to ride to Win ... Now I ride to Grin
    While my guitar gently weeps, my bike sits there mocking me
  1. Basic Cleaning and Maintenance Guide
    By SteveUK in forum Beginner's Corner
    Last Post: 09-18-2017, 07:33 PM
  2. Replies: 3
    Last Post: 10-13-2012, 06:46 PM
  3. basic maintenance on an air fork - SID
    By mat-with-one-t in forum Shocks and Suspension
    Last Post: 03-14-2012, 05:11 PM
  4. The best way to learn basic bike maintenance?
    By uzyrmind in forum Beginner's Corner
    Last Post: 01-26-2012, 10:52 PM
  5. Basic fork maintenance
    By Eric Z in forum Beginner's Corner
    Last Post: 07-15-2011, 08:12 PM
